Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
#88
(01-20-2021, 08:42 AM)FutureBucket Wrote:
(01-20-2021, 08:09 AM)kop316 Wrote:
(01-20-2021, 07:58 AM)FutureBucket Wrote:
(01-19-2021, 11:54 AM)kop316 Wrote: The one outstanding issue is whether mmsd works with MMS proxies that are IP addresses only. I have had someone test this issue on AT&T (change the domain to the IP address manually), and they reported success with mmsd, but said there may be an purple-mm-sms issue.
However, in either case, I unfortunately cannot test this issue. If someone can hunt down this issue (and find a fix, or show me where the fix needs to go), I would greatly appreciate it.
Hey, Canadian here, From looking though this thread I believe the problem is with Telus? I have a Telus SIM and the PMos Community Edition PinePhone. I'll play around with it this week/weekend.
Don't get too excited though, I'm more of Intermediate Linux Admin than a Dev. I've only really compiled a handful of things from source so it may take me a bit to get to a point where I can troubleshoot. I'm very interested in learning and helping though!
Hello from your neighbor south of the border! You are correct, the reported issue was with Telus.
I should have all of the instructions up on the first post ro get you up and running to debug. From another user (who emulated the conditions with AT&T USA), it seems that it may not be with mmsd itself, but some interaction between mmsd and purple-mm-sms.
And if you are interested in learning and helping, I am happy! If you need any help, feel free to reply here or in the pmOS matrix chat. There's a few folks that are using the mmsd stack in there.
Yeah man, I want to build a Chatty <-> Matrix integration for the PinePhone and it's going to support MMSes so I need to start here. I hate picking up my phone to reply to people when I have 2 computers in front of me already... I already have something for Ubuntu Touch and ofono on my Nexus 5 Smile
I'm at work for the next ~7 hours (and really shouldn't be on here) but I'll get started after. I'll join the Matrix group around then too. Cheers.
So depending on what you want to do, I want you to be aware of a couple of things:
- mmsd does not need chatty to work, that is just the higher level application I have been working which since I want chatty to support MMS. You can write your own program to process SMS/MMS (or MMS only) and it can work with mmsd
- Purism is working already to support matrix into chatty. As soon as they have a stable codebase, my goal is to then integrate MMS more fully into chatty.
So with more stability, comes more testing, which discovers more bugs. I have reworked mmsd and the modem manager plugin a bit more. The primary feature added is the modem manager plugin can much better handle if the modem is disconnected from mobile data, and a program can activate mmsd to process messages waiting to be sent/recieved manually! This is really good news to make mmsd handle real life scenarios.
Until I/someone else discover more bugs, the only outstanding issue is the MMS proxy issue.
RE: Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! - by kop316 - 01-20-2021, 09:21 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,553 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 990 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,602 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,050 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,183 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,691 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,248 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 130,879 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,097 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,709 06-13-2022, 02:01 PM
Last Post: israel
