Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
#54
(01-12-2021, 12:03 PM)kop316 Wrote: So if anyone has experience with systemd, help would be appreciated.
I am making a systemd serve with:
[Unit]
Description=Multimedia Message Service Daemon
Wants=network.target
After=syslog.target network-online.target
[Service]
Type=simple
ExecStart=/usr/libexec/mmsd
Restart=always
RestartSec=10
User=root
KillMode=process
[Install]
WantedBy=multi-user.target
and I put it here: /etc/systemd/system/mmsd.service (it is owned by root, and has permissions of 640)
I attempt to enable it and start it with:
sudo systemctl enable mmsd
sudo systemctl daemon-reload
sudo systemctl start mmsd
But mmsd imediately stops.
When installing the normal way. I can manually start it with:
$/usr/libexec/mmsd
and it runs as I expect it to.
I'm by no means an expert, but wouldn't you want permissions to be 740? So that root has the ability to execute the service as well?
RE: Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! - by cody - 01-12-2021, 12:52 PM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,697 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,044 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,647 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,171 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,271 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,752 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,295 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 132,135 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,165 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,760 06-13-2022, 02:01 PM
Last Post: israel
Users browsing this thread: 9 Guest(s)
