Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
#31
Something is still not working quite right. Here's what mmsd is outputting at the end of the attachment download request:
bytes read 40
[body] length 40
bytes read 903
[body] length 903
bytes read 0
mmsd[14964]: src/service.c:web_get_cb() status: 200
mmsd[14964]: src/service.c:web_get_cb() data size = 833811
mmsd[14964]: src/service.c:web_get_cb() request->result_cb=0xaaaac94dc610 vs. retrieve_conf=0xaaaac94dc610/send_conf=0xaaaac94da6c0/notify_resp=0xaaaac94dd400
mmsd[14964]: src/store.c:generate_uuid_from_pdu() pdu 0xffffab720000 len 833811
mmsd[14964]: src/store.c:mms_store_file() pathname /home/manjaro/.mms/any/A0E4098838D985980D725864ED21EE07B8A92867
When a mms comes in, mmsd outputs pages of "bytes read/[body] length" entries and then pauses for a good 30 seconds before popping up the final "bytes read 0". After that, the process continues to completion pretty quickly. The output reports a bit over 8K stored, and the file in ~/.mms/any matches the reported size.
On the Chatty side, the sms comes in immediately. A separate conversation is created with the "a mms has arrived, trying to d/l" message. After the mmsd long pause, 7 "file already exists" error messages pop up in the sms conversation. In ~/mms, an empty directory coded by date-time-sender is created for the mms that matches the Chatty error messages.
I'm not sure where the breakdown is happening.  I spent some time tracing the debug output through the mmsd code and there is nothing obviously amiss on the mmsd side. It looks like mmsd is properly getting the download, but that long pause after the data chunks might be significant.
How does the handoff to purple-mms-sms work? Is purple creating the files in ~/mms from the raw files in ~/.mms/any?
Also, does mmsd output a logfile somewhere? Debug output for 8k of chunks has overwhelmed my ssh buffer.
RE: Experimental support MMS on chatty - help/testing wanted! - by kent - 01-05-2021, 01:33 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,449 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 940 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,571 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 2,964 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,120 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,629 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,215 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 129,055 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,060 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,662 06-13-2022, 02:01 PM
Last Post: israel
