Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
#27
(01-04-2021, 12:20 PM)kent Wrote:
(01-03-2021, 02:09 PM)kop316 Wrote: So are you able to recieve MMS now then?
I *think* so. Or at least the process has gotten farther and mmsd is getting data through AT&T's proxy now.
I cleared out the mms working folder, updated to the latest purple-mm-sms,  and sent a test mms with an image attachment.
Now with an inbound mms, Chatty displays the sms message plus an error message indicating a file already exists; similar to the screenshot you posted near the start of the thread.
I'm not sure what the end result is supposed to look like in Chatty at this point. Is that right?
That is right! so what you may need to do (I have had to do this for experiementing) is delete both the .mms/ and mms/ folder in your home folder. That usually cleans up those errors.
Please let me know what you did for getting the proxy!
RE: Experimental support MMS on chatty - help/testing wanted! - by kop316 - 01-04-2021, 01:00 PM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,604 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,001 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,620 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,085 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,212 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,705 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,266 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 131,072 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,128 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,717 06-13-2022, 02:01 PM
Last Post: israel
