Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
#24
(01-03-2021, 01:44 PM)kent Wrote:
(01-03-2021, 07:57 AM)kop316 Wrote:
(01-02-2021, 09:40 PM)kent Wrote: Getting closer ... but not quite there. Chatty now creates a conversation with a message indicating a MMS notification has arrived via sms which Chatty is working to download and parse.
Based on the mmsd output, it looks like the request never actually goes out though.
mmsd[6172]: src/service.c:mms_service_push_notify() did decode message
mmsd[6172]: src/service.c:mms_service_push_notify() is type NI?
mmsd[6172]: src/service.c:mms_service_push_notify() type is NI
mmsd[6172]: MMS transaction id: A20103012201500004000000000
mmsd[6172]: MMS version: 1.0
mmsd[6172]: From: +15555555555/TYPE=PLMN
mmsd[6172]: Subject:
mmsd[6172]: Class: Personal
mmsd[6172]: Size: 32768
mmsd[6172]: Expiry: 2021-01-06T01:22:04+0000
mmsd[6172]: Location: http://166.216.198.5:8004/Y/0103012201500004000000000
mmsd[6172]: src/service.c:mms_service_push_notify() about to store_meta_open 2
mmsd[6172]: src/service.c:mms_service_push_notify() did store_meta_open 2
mmsd[6172]: src/service.c:mms_service_push_notify() did create_request
mmsd[6172]: src/service.c:activate_bearer() service 0xaaab0c023bf0 setup 0 active 1
mmsd[6172]: src/service.c:process_request_queue() service 0xaaab0c023bf0
mmsd[6172]: src/service.c:process_request_queue() location http://166.216.198.5:8004/Y/0103012201500004000000000
request http://166.216.198.5:8004/Y/0103012201500004000000000
address proxy.mobile.att.net
port 80
host 166.216.198.5:8004
flags 0
mmsd[6172]: Cannot process request (request type: 0)
The problem tracks back to the do_request() function call in gweb.c.  There is a getaddrinfo() command failing with a "Name or service not known" error code trying to resolve the proxy host information, but I can't figure out exactly why (~line#1320) . I verified the values being passed for the name and port inputs look correct, and verified "proxy.mobile.att.net" host resolves fine with a manual ns lookup.
I'm stumped for the moment.
If you have a matrix account, I generally hang out on the mobian and pmOS channels. Perhaps me helping you live would be easier?
I don't have a matrix account ... but I'll look into it. Any help is appreciated, but mostly I'm logging progress here in case something I'm coming across is useful (and I'm enough of a noob I can't quite tell the difference yet). I don't expect you to stop what you are working on to solve everything.
I figured out what's going on. There is an addr_info() flag requiring a numeric ip address, which disables DNS lookup. The easiest solution is to just comment out that flag so addr_info() resolves a text domain name. This seems to work, but I'm not sure if that will break something else. So I've put in a hack at that level to do a dns lookup and replace if the session->address is not a valid numeric ip address.
This hack probably isn't a great final solution for production though.
Also, turns out it is possible to make a bloody mess of the mmsd request queue. There probably needs to be logic that eventually removes queue entries that can't be resolved (e.g. 404 Message not found in database).
Sounds good! Don't worry about being a "noob", we all were there once (heck, that's how I felt about this whole thing before digging into it). I appreicate you digging in and looking at the code to figure it out!
I think the next logical place to work on is actually mmsd, and work on a more complete integration with it and modem manager (and possibly clean up the code too). So far, since I was able to send/recieve MMS, I have largely treated it as a black box (and I have made a huge mess of the request queue too). But purple-mm-sms is in good enough shape that it needs work to integrate into chatty, and I am waiting on Purism to look at the MR I sent to them.
So are you able to recieve MMS now then?
RE: Experimental support MMS on chatty - help/testing wanted! - by kop316 - 01-03-2021, 02:09 PM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,607 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,003 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,622 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,092 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,221 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,717 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,271 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 131,133 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,133 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,720 06-13-2022, 02:01 PM
Last Post: israel
