Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
(01-02-2021, 08:10 AM)kop316 Wrote: So looking to it more, this may be an issue with our interface with Modem manager in mmsd. The one that exists now is extremely simple (hence the title "simple.c"). One of the things that looks needing to be done is set up  the ability to do the proxy service from within mmsd.
At a quick glance, this may need to be done from within "bearer handler"? But I have not looked too much into this.
However I would say, if you have the know how, this would be a great way to help get MMS, if you could get the MMS proxy integrated into the mmsd plugin.
EDIT:
So looking at this a bit more, I am seeing a couple of functions that look promising:
mms_service_bearer_notify() and mms_service_set_bearer_handler().
mms_service_bearer_notify() looks like it has references to setting a proxy, and it's pretty straight foward to integrate it into simple.c (in line 82 where it says:
mms_service_bearer_notify(service, TRUE, "wwan0", NULL);
Change the "NULL" to the proxy service and see how that works.
mms_service_set_bearer_handler() may have to be set, but I am not sure what it does. Perhaps look at the ofono.c plugin and see how it sets up the proxy too? This is how the debug looks for me:
mmsd[3297]: src/service.c:mms_service_create() service 0x55abbb9dc0
mmsd[3297]: src/service.c:mms_service_set_identity() service 0x55abbb9dc0 identity any
mmsd[3297]: src/service.c:mms_service_set_mmsc() service 0x55abbb9dc0 mmsc http://mms.msg.eng.t-mobile.com/mms/wapenc
mmsd[3297]: src/service.c:mms_service_bearer_notify() service=0x55abbb9dc0 active=1 iface=wwan0 proxy=(null)
mmsd[3297]: src/service.c:mms_service_bearer_notify() interface wwan0 proxy (null)
clearing proxy
I'll play with the proxy settings and see what happens.
What does T-Mobile send in the CONTENT_LOCATION header? AT&T is sending:
mmsd[4645]: src/mmsutil.c:mms_parse_headers() saw header of type 3
mmsd[4645]: src/mmsutil.c:mms_parse_headers() running handler for type 3
mmsd[4645]: src/mmsutil.c:decode_text() claimed len: 54
mmsd[4645]: src/mmsutil.c:decode_text() val: http://166.216.198.5:8009/Y/0102054534500019000010000
mmsd[4645]: src/mmsutil.c:mms_parse_headers() handler for type 3 was success
RE: Experimental support MMS on chatty - help/testing wanted! - by kent - 01-02-2021, 05:43 PM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,609 10-18-2023, 08:37 AM
Last Post: luppivega
  A/B testing or Unit testing gulshan212 0 1,004 08-29-2023, 03:36 AM
Last Post: gulshan212
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 1,622 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 3,096 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 3,221 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 2,720 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 2,272 08-25-2022, 04:09 PM
Last Post: vortex
  Latest firmware for PinePhone modem! Subsentient 104 131,183 07-20-2022, 05:32 AM
Last Post: zetabeta
  Which PP OS currently has the best podcast support? kujo_marble 3 2,133 07-14-2022, 07:09 AM
  Help wanted: location of calls and chatty data files dukla2000 3 4,723 06-13-2022, 02:01 PM
Last Post: israel
