(01-01-2021, 05:05 PM)kent Wrote:Yes it is, just make sure you check out the mmsd branch.(01-01-2021, 01:04 PM)kop316 Wrote: So If you can, please download a later version of purple-mm-sms. What is going on is that when you get an MMS, it first downloads what is called an "SMS WAP". This is a notification to go to a link and download the actual payload. I made that a bit clearer in a newer version of purple-mm-sms (and i cleaned upquite a bit of the code too):The link for purple-mm-sms here will not directly clone w/ git. I'm cloning from https://source.puri.sm/kop316/purple-mm-sms/.
https://source.puri.sm/kop316/purple-mm-sms/-/tree/mmsd
Also, are you running mmsd?
And the repo for chatty is:
https://source.puri.sm/Librem5/chatty
without a more detailed log of mmsd or chatty, I am not sure i can help?
Is this the correct version?
