LCD screen not powering on
(06-03-2016, 03:44 PM)Dup Wrote:
(06-03-2016, 03:38 PM)Dnode Wrote:
(06-03-2016, 10:49 AM)Dup Wrote:
(06-03-2016, 04:21 AM)Luke Wrote: Hi Dup
I got a few questions before I can suggest some trouble shooting:
1) What PSU and AWG cable are you using ? (does the touchscreen have dedicated power ? - I don't own one so I don't know)
2) What peripherals do you have connected during first boot - you say you pulled the Wifi/BT hat off - anything else plugged in?
3) Have you remembered to set  'Startup!' in Phoenix ?
A general note: after you boot a phoenix image, do note that it may take up-to 15 min for background processes to complete. Let it sit there after it boots for a while.
Its 5V 2A. Not sure on cable gauge but its fairly thick. Not a thin USB cable. I'm not even sure how I could even give the touchscreen separate power. It only has two ribbon cables that plug into the Pine.
No peripherals connected.
As stated, it was created with Startup
I had no idea it could take up to 15 min !!! Thats quite long. I suppose I will try to let it sit. That seems nuts.
What's the spec of your MicroSD card?  It should be at minimum a Class 10.
Class 10 SanDisk. All of the other images I have tried have booted fine, (obviously not with the screen because the android is the only one that supports it).
Its actually a UHS 1 card.
That should work.  Yours never gotten to the white screen with a pine cone logo even after leaving it on for a while?
LCD screen not powering on - by Dnode - 06-02-2016, 06:35 PM
RE: LCD screen not powering on - by Luke - 06-02-2016, 06:45 PM
RE: LCD screen not powering on - by Dup - 06-02-2016, 08:45 PM
RE: LCD screen not powering on - by Dnode - 06-02-2016, 09:19 PM
RE: LCD screen not powering on - by Dup - 06-02-2016, 10:54 PM
RE: LCD screen not powering on - by Luke - 06-03-2016, 04:21 AM
RE: LCD screen not powering on - by Dup - 06-03-2016, 10:49 AM
RE: LCD screen not powering on - by Dnode - 06-03-2016, 03:38 PM
RE: LCD screen not powering on - by Dup - 06-03-2016, 03:44 PM
RE: LCD screen not powering on - by Dnode - 06-03-2016, 04:18 PM
RE: LCD screen not powering on - by Dup - 06-03-2016, 04:24 PM
RE: LCD screen not powering on - by Dnode - 06-03-2016, 04:34 PM
RE: LCD screen not powering on - by Dup - 06-03-2016, 04:35 PM
RE: LCD screen not powering on - by Dnode - 06-03-2016, 07:33 PM
RE: LCD screen not powering on - by anexpert - 06-08-2016, 12:59 PM
RE: LCD screen not powering on - by Dup - 06-03-2016, 08:00 PM
RE: LCD screen not powering on - by Luke - 06-04-2016, 06:44 PM
  What other devices can the LCD screen work on? kodachrome 1 3,140 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 35,640 07-21-2017, 07:41 AM
Last Post: apple4ever
  LCD screen brightness/contrast Learnincurve 10 14,037 02-17-2017, 12:45 PM
Last Post: psychedup
  Touch screen support shariq_2001 14 20,100 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 9,785 11-27-2016, 10:26 PM
Last Post: michaelquezon
  Screen flashes blue and then goes dark. tanarri 5 7,800 06-22-2016, 10:53 AM
Last Post: tanarri
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 5,148 06-13-2016, 08:24 AM
Last Post: PapaStahl
  Petition thread for screen larger than 7inch MostHated 4 5,443 03-02-2016, 03:40 PM
Last Post: MostHated
