Safe to Update?
On manjaro you can choose three main branches: arm-stable, arm-testing and arm-unstable.
You set them editing /etc/pacman-mirrors.conf
By default Manjaro set it to stable branch.
Usually if you're on stable channel you should be almost safe when updating... there will be issues every now and then but it's the price you pay for a rolling release and it's nothing you can't resolve with a quick search.
Even the arm-testing should be safe enough if you follow the manjaro forum.
I'm running the arm-unstable branch and so far i just had to downgrade mesa package a couple of time but it's a known issue. I've had occasionally problems with wayland but reverting to X11 solved them for the time being.
Other issues may come from AUR packages but using the. usually involves a bit of knowledge on how your system works if you're planning to install sensitive packages.
Safe to Update? - by BluBombr64 - 12-11-2020, 03:52 PM
RE: Safe to Update? - by jiyong - 12-12-2020, 05:26 AM
RE: Safe to Update? - by BluBombr64 - 12-16-2020, 05:34 PM
RE: Safe to Update? - by jiyong - 12-17-2020, 03:58 AM
RE: Safe to Update? - by jiyong - 12-17-2020, 08:12 AM
RE: Safe to Update? - by nightranger73 - 12-17-2020, 09:27 AM
RE: Safe to Update? - by BluBombr64 - 12-18-2020, 11:59 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,247 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 1,054 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,065 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,330 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,430 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,108 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 5,984 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,382 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 2,591 10-19-2021, 01:57 AM
Last Post: j4n3z
  Trackpad firmware update Luke 263 361,647 07-28-2021, 12:52 PM
Last Post: Luke
