Pinebook Pro Dock Power Requirements
(12-06-2020, 04:54 PM)KC9UDX Wrote: The PBP currently (pun?) only draws about 2.5A from the USB-C connector in any case.  Except for future modifications, more than 15W won't do any good.  Reports are that it draws closer to 3A from the barrel jack; and the power circuitry would need a major redesign to accept more than that.
Actually, I was referring to the dock being poorly designed from the standpoint of getting the PineBook Pro modified to take and use more input power.  We'll get it there eventually, Smile so having an inferior dock would be sad.
The BQ24171 chip inside the PineBook Pro is configured to pull less power from the Type-C port, compared to what it is configured to pull from the barrel jack.  Unfortunately, all that is configured using SMT resistors on the PCB, which makes any modifications rather inconvenient.
(12-11-2020, 03:30 AM)xyzzy Wrote: I don't think it would be a major redesign.  The main power supply, a BQ24171, is rated to 17V.  It should be possible to get 45W with 15V-3A over USB-C with only minor changes to a few components.
Right, it should not be overly complicated as a modification, and using 3 A at 9 V from the Type-C port should be the easiest option.  All that is already on my to-do list.
Pinebook Pro Dock Power Requirements - by calinb - 12-06-2020, 11:34 AM
RE: Pinebook Pro Dock Power Requirements - by dsimic - 12-16-2020, 09:24 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 3 569 10 hours ago
Last Post: segaloco
  Pinebook Pro on Debian 12 Power Issue u974615 1 352 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 291 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 275 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 633 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,123 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,950 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,060 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,480 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,141 11-30-2022, 04:28 PM
