Would you like to see and buy the 2.2 revision?
Yes, please!
91.67%
55
No, thank you
8.33%
5
60 vote(s)
PineBook Pro revision 2.2: Wishlist for the hardware issue fixes
Built in debug console to usb conversion with a micro-usb port on the side. This would avoid needing to switch between usb and headphones, fix incorrect voltage on serial console cable (should be 3V, not 3.3V and not 5V!), eliminate the need for a special debug cable in the first place, fix the danger of connecting a serial cable without an opto-isolator, and prevent possible noise on audio lines from injecting garbage on the serial port that prevent u-boot from starting.
This only requires a simple chip and connector, it looks like there is plenty of space for it.
Rotate touchpad 180 degrees so that the physical buttons are under the top corners, rather than the bottom corners.
RE: PineBook Pro 2.2 revision: Wishlist for the hardware issue fixes - by xyzzy - 12-11-2020, 04:33 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 751 05-06-2024, 09:27 AM
  New Hardware names_mark_ 1 261 04-23-2024, 08:41 AM
Last Post: dachalife
  Pinebook Pro on Debian 12 Power Issue u974615 1 380 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 325 02-17-2024, 07:06 PM
  Pine Dock Networking Issue trillobite 1 307 02-10-2024, 12:03 AM
Last Post: trillobite
  Pinebook Pro charging issues tomekdev 1 662 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,170 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,902 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 3,125 08-12-2023, 01:59 AM
Last Post: User 27258
  PineBook Pro dead ottahe 9 6,149 01-18-2023, 07:41 PM
Last Post: ottahe
