PBP Not Charging
(11-26-2020, 07:50 AM)pljanson Wrote:
(11-26-2020, 07:31 AM)wolf Wrote: Since getting my pbp a few months ago it has occasionally failed to start up due to an unexpected empty battery. This has been regardless of the level of charge on the last shutdown and often even occurred while plugged in for topping up. So far, the remedy has been to let it continued charging for a day or so.
Happened again a few days ago but now it won't charge at all and can't even be started, despite being plugged in and charging that whole time. Pressing the start button (whether it's plugged in or not) lights up the amber LED, sometimes goes to green, as normal... but then turns off. It once got to the login screen, showed the battery at 0%, and died.
Up till now the battery, once charged, has had decent life, so it's probably not a bad battery. Although I don't think I've ever seen it at more than 60-70% regardless of the time it's been on the charger.
Any thoughts?
Mine (first batch PBP with initially the MrFixit release, now on Manjaro) never decently charged with the provided charger and barrel plug, but "just works" with USB-C charging.
Red charging light goes out on barrel plug, or was not really charging but on, and I expect internal HW issue, but never looked into it since I now just charge with USB-C.
(And hope to get the dock with USB-C and that charging via it will work).
Hope this helps.
which usb-c charger (quick charging?) do you use? And anyone an idea what charger should be used with the dock (in the announcement it was mentioned that the dock can also provide power to accessories connected)...
I am regularly checking the store for the usb-c dock, but still no avail... Sad
PBP Not Charging - by wolf - 11-26-2020, 07:31 AM
RE: PBP Not Charging - by pljanson - 11-26-2020, 07:50 AM
RE: PBP Not Charging - by appelgriebsch - 11-26-2020, 01:06 PM
RE: PBP Not Charging - by dsimic - 11-26-2020, 02:53 PM
RE: PBP Not Charging - by wolf - 11-26-2020, 03:47 PM
RE: PBP Not Charging - by KC9UDX - 11-26-2020, 03:57 PM
  Pinebook Pro charging issues tomekdev 1 658 01-05-2024, 08:40 PM
Last Post: tomekdev
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,874 07-09-2021, 08:45 PM
Last Post: moonwalkers
Photo PineBook Docking Deck charging port? ColoBill 3 5,301 02-26-2021, 10:07 PM
Last Post: Paull
  USB-C charging specifications zxorg 11 14,185 07-12-2020, 10:23 AM
Last Post: zxorg
  Not charging via barrel plug anymore LutzFechner 1 2,869 03-01-2020, 11:33 PM
Last Post: decisivedove
  Improving charging of PBP battery james64 8 10,235 02-04-2020, 02:54 AM
Last Post: bcnaz
