Not charging via barrel plug anymore
my PBP stopped charging via the plug a few minutes ago.
Battery is now at 89%.
Voltage on the Adapter is 5.39V.
Charging via USB still seems to be fine....
Anyone else has this or knows how to fix that?
Hi LutzFechner,
Try powering it off and charge it for a few minutes. Then turn it on and check to see if the battery percentage has increased. Let us know if it works fine after that.
  Pinebook Pro charging issues tomekdev 1 579 01-05-2024, 08:40 PM
Last Post: tomekdev
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,852 10-21-2022, 07:57 AM
Last Post: dachalife
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,749 07-09-2021, 08:45 PM
Last Post: moonwalkers
  can the PBP draw more than 3A from the barrel socket? dieselnutjob 2 3,217 03-26-2021, 07:56 AM
Last Post: dsimic
Photo PineBook Docking Deck charging port? ColoBill 3 5,202 02-26-2021, 10:07 PM
Last Post: Paull
  PBP Not Charging wolf 5 7,000 11-26-2020, 03:57 PM
  USB-C charging specifications zxorg 11 13,914 07-12-2020, 10:23 AM
Last Post: zxorg
  Improving charging of PBP battery james64 8 10,074 02-04-2020, 02:54 AM
Last Post: bcnaz
