Axolotl on PinePhone / Mobian
#38
(02-11-2021, 03:54 AM)arno_nuehm Wrote:
(02-11-2021, 03:29 AM)kqlnut Wrote: What's the proper way to update Axolotl once you have it installed? "git pull", "go get -u", and then rebuild with the last two steps from the installation tutorial? I don't know how go works, but it would be cool to know how to update the app including the dependencies without redoing the whole procedure.
That is a good question. I usually rename the ~/home/go folder, since it is only used for Axolotl in my case and then redo every step - which is awfully inconvenient.
But I will dig into it later!
Cheers
I did update just now by going into the axolotl folder, running "git pull", "go get -u" and then rebuilding with the last two steps in your instructions. The app runs fine and shows the updated version. But I'm not sure if I correctly updated the dependencies with these steps ... Updates for stuff like textsecure v1.2.13 showed up, but I don't know if that's enough to have it all in the right place.
Axolotl on PinePhone / Mobian - by arno_nuehm - 11-06-2020, 11:24 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-06-2020, 04:46 PM
RE: Axolotl on PinePhone / Mobian - by User 18618 - 11-11-2020, 04:25 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-16-2020, 07:05 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-16-2020, 10:32 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2020, 11:51 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 11-18-2020, 02:38 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2020, 01:49 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 12-07-2020, 03:03 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-07-2020, 04:20 AM
RE: Axolotl on PinePhone / Mobian - by marcih - 12-07-2020, 05:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-07-2020, 05:54 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-16-2020, 07:06 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-19-2021, 04:16 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-25-2021, 05:17 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-26-2021, 03:25 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-28-2021, 05:47 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-29-2021, 07:39 AM
RE: Axolotl on PinePhone / Mobian - by acm006 - 12-21-2020, 02:00 PM
RE: Axolotl on PinePhone / Mobian - by Ersatz - 12-21-2020, 08:38 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-22-2020, 04:59 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 08:48 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 12:11 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2021, 02:32 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-02-2021, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-03-2021, 03:27 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-04-2021, 04:05 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-04-2021, 04:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-05-2021, 04:51 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 03:29 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 03:54 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 04:05 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 08:48 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 02-11-2021, 11:01 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-11-2021, 03:58 PM
RE: Axolotl on PinePhone / Mobian - by RTP - 02-11-2021, 04:35 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-12-2021, 04:35 PM
RE: Axolotl on PinePhone / Mobian - by marcih - 02-13-2021, 03:11 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 02-13-2021, 05:47 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-13-2021, 08:04 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-25-2021, 06:22 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 02-25-2021, 09:16 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-27-2021, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 03-06-2021, 02:51 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-06-2021, 04:56 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-09-2021, 04:25 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-09-2021, 05:51 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-17-2021, 02:31 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-17-2021, 03:15 PM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-18-2021, 06:46 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-18-2021, 11:07 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-18-2021, 12:30 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-18-2021, 02:12 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-19-2021, 03:56 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-19-2021, 06:10 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 03-19-2021, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-19-2021, 06:32 AM
RE: Axolotl on PinePhone / Mobian - by Pelecanus - 03-19-2021, 08:42 AM
RE: Axolotl on PinePhone / Mobian - by RTP - 03-15-2021, 03:54 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 03-19-2021, 10:21 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-05-2021, 12:48 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-13-2021, 05:59 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 12:42 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 01:45 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-28-2021, 02:26 PM
One single contact broken in Axolotl - by Anna - 05-06-2021, 04:08 AM
RE: Axolotl on PinePhone / Mobian - by Avatars - 05-10-2021, 07:07 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 05-13-2021, 05:38 AM
RE: Axolotl on PinePhone / Mobian - by Avatars - 05-13-2021, 05:42 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 05-14-2021, 05:50 AM
RE: Axolotl on PinePhone / Mobian - by richieeee - 05-20-2021, 01:31 PM
RE: Axolotl on PinePhone / Mobian - by Cree - 05-20-2021, 12:30 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 05-28-2021, 07:52 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-02-2021, 12:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 06-02-2021, 05:42 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-03-2021, 03:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 06-03-2021, 11:06 AM
RE: Axolotl on PinePhone / Mobian - by ergo owl - 06-11-2021, 07:16 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 06-23-2021, 08:13 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-06-2021, 02:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-12-2021, 01:46 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-10-2021, 05:19 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-20-2021, 02:09 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 07-20-2021, 01:34 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-21-2021, 02:39 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 07-21-2021, 02:35 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 07-23-2021, 12:32 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-27-2021, 06:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-28-2021, 05:23 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-28-2021, 07:55 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-04-2021, 07:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-06-2021, 02:29 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-16-2021, 08:22 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 09-16-2021, 11:15 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 09-16-2021, 02:19 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 09-17-2021, 01:21 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-17-2021, 02:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-26-2021, 10:21 AM
RE: Axolotl on PinePhone / Mobian - by juju - 09-26-2021, 07:12 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-27-2021, 01:58 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 09-30-2021, 04:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-21-2021, 01:24 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 10-21-2021, 01:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-28-2021, 09:44 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-04-2021, 02:02 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 11-17-2021, 10:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2021, 10:38 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-17-2021, 02:14 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-17-2021, 03:02 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-19-2021, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-23-2021, 02:43 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-24-2021, 11:34 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-24-2021, 11:48 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-24-2021, 02:46 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-23-2021, 09:34 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 11-29-2021, 07:34 AM
RE: Axolotl on PinePhone / Mobian - by kqlnut - 11-29-2021, 10:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-29-2021, 11:56 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-30-2021, 03:47 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-02-2021, 03:09 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-03-2021, 04:36 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2021, 11:29 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-06-2021, 12:00 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-06-2021, 12:48 PM
RE: Axolotl on PinePhone / Mobian - by Anna - 12-12-2021, 02:46 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 12-12-2021, 12:57 PM
RE: Axolotl on PinePhone / Mobian - by ichbins - 12-16-2021, 01:14 PM
RE: Axolotl on PinePhone / Mobian - by eFqLLnGo - 12-17-2021, 05:25 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-20-2022, 06:24 AM
RE: Axolotl on PinePhone / Mobian - by DominiqueM - 01-20-2022, 08:06 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 01-21-2022, 04:45 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-01-2022, 01:05 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-13-2022, 04:33 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 02-16-2022, 04:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 02-16-2022, 04:41 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 03-15-2022, 05:57 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-17-2022, 03:41 AM
RE: Axolotl on PinePhone / Mobian - by user641 - 03-17-2022, 04:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 03-17-2022, 11:43 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-04-2022, 07:43 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-04-2022, 09:03 AM
RE: Axolotl on PinePhone / Mobian - by Anna - 04-05-2022, 05:40 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-05-2022, 06:30 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 04-14-2022, 03:16 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-09-2022, 02:10 PM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 08-11-2022, 02:28 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-15-2022, 11:26 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-19-2022, 01:33 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 08-20-2022, 07:47 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 08-23-2022, 04:17 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 08-23-2022, 09:37 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-04-2022, 06:50 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-04-2022, 07:10 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 09-04-2022, 11:41 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-05-2022, 11:00 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-05-2022, 02:24 PM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-05-2022, 12:55 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-06-2022, 12:33 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 09-06-2022, 01:00 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-08-2022, 05:24 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 09-11-2022, 05:35 PM
RE: Axolotl on PinePhone / Mobian - by Eugo - 09-12-2022, 02:55 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-17-2022, 09:01 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 10-27-2022, 01:51 PM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-27-2022, 03:31 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 10-28-2022, 05:17 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 10-29-2022, 09:16 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 10-31-2022, 04:56 AM
RE: Axolotl on PinePhone / Mobian - by Eugo - 11-01-2022, 05:22 AM
RE: Axolotl on PinePhone / Mobian - by benedikt55 - 11-01-2022, 08:10 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-01-2022, 04:02 PM
RE: Axolotl on PinePhone / Mobian - by Eugo - 11-02-2022, 08:43 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-08-2022, 09:18 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-08-2022, 03:08 PM
RE: Axolotl on PinePhone / Mobian - by benedikt55 - 11-09-2022, 04:02 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 11-10-2022, 02:12 AM
RE: Axolotl on PinePhone / Mobian - by arno_nuehm - 11-10-2022, 02:40 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-23-2023, 03:46 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-24-2023, 02:07 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-27-2023, 02:54 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-27-2023, 04:38 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-27-2023, 04:52 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 01-27-2023, 07:06 AM
RE: Axolotl on PinePhone / Mobian - by dukla2000 - 01-27-2023, 06:08 PM
RE: Axolotl on PinePhone / Mobian - by dante404 - 01-29-2023, 10:52 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 02-07-2023, 02:19 AM
RE: Axolotl on PinePhone / Mobian - by dante404 - 03-13-2023, 09:14 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-22-2023, 12:05 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 03-22-2023, 04:17 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-22-2023, 04:58 AM
RE: Axolotl on PinePhone / Mobian - by zetabeta - 03-22-2023, 10:48 AM
RE: Axolotl on PinePhone / Mobian - by shulamy - 03-26-2023, 01:49 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,122 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 181 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,279 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 209 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,820 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,243 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,944 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 692 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,279 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,982 07-09-2023, 01:37 AM
Last Post: vusra
