Graphical login hanging after password entry
Because X is running on tty1, but not on tty2. A tty is a "virtual terminal", meaning it is supposed to represent an actual physical screen and keyboard, etc. The terminals are all on simultaneously, but since you only have enough hardware to interface with one at a time, that's what you get.
You can in fact run multiple X sessions on different ttys and switch between them. You need a valid ~/.xinit or ~/.Xclients first. If you don't, for illustration:
just try this and thanks me later
echo -e "#!/bin/sh\n mwm" > ~/.xinit
chmod u+x ~/.xinit
If there isn't a display manager doing something totalitarian, you should get a plain black window with a big X mouse cursor. Left clicking should give a crude looking menu from which you can now "Quit"; but before that CtrlAltF1 will take you to the other X session on tty1 (and F2 gets you back, etc.).
___________________________________
Gordon Bullard & Company
RE: Graphical login hanging after password entry - by jacksonliam341 - 03-29-2021, 08:32 AM
  oem password iwm 8 2,417 02-19-2023, 07:35 PM
Last Post: iwm
  pinebook pro wiki link on the website links to the wrong wiki entry Julius_GU 0 1,357 02-11-2021, 10:27 AM
Last Post: Julius_GU
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,764 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  PBP Went Blank After Login iscmob 2 2,998 12-07-2020, 09:28 AM
Last Post: iscmob
  Pinebook Pro Won't Accept Login GFreeman 16 16,547 09-03-2020, 11:44 AM
  [split] Change password from external media James Good 11 12,898 07-23-2020, 02:42 PM
  Login screen issue. LinuXchoicE 2 4,139 07-07-2020, 09:06 AM
Last Post: LinuXchoicE
  Stuck on login screen Kscott6969 0 1,924 04-20-2020, 10:58 PM
Last Post: Kscott6969
  PBP Complete Loss of Password Recognition jcj52436999 2 3,407 03-16-2020, 05:38 PM
Last Post: jcj52436999
  default os: loop while login as rock gritibaenz 8 8,264 03-10-2020, 03:14 PM
Last Post: gritibaenz
