Won't boot with SATA card
I had the Pine64 NAS working for a week with the 2x HDD's working as a stripped RAID array. I did a software update "apt-get dist-upgrade" and has this at reboot:
[ 0.000000] Linux version 5.8.16-rockchip64 (root@xeon) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #20.08.14 SMP PREEMPT Tue Oct 20 22:37:51 CEST 2020
[ 0.000000] Machine model: Pine64 RockPro64 v2.1
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000ff1a0000 (options '')
[ 0.000000] printk: bootconsole [uart8250] enabled
[ 17.979376] Internal error: synchronous external abort: 96000210 [#1] PREEMPT SMP
[ 18.003131] Modules linked in: snd_soc_hdmi_codec panfrost pwm_fan snd_soc_audio_graph_card snd_soc_simple_card gpu_sched snd_soc_simple_card_utils rc_cec dw_hdmi_i2s_audio fusb302 dw_hdmi_cec tcpm snd_soc_rockchip_i2s snd_soc_es8316 rockchip_vdec© hantro_vpu© typec snd_soc_core rockchip_rga v4l2_h264 hci_uart videobuf2_vmalloc videobuf2_dma_contig videobuf2_dma_sg snd_pcm_dmaengine v4l2_mem2mem btqca videobuf2_memops snd_pcm btrtl videobuf2_v4l2 btbcm btintel videobuf2_common bluetooth videodev snd_timer mc snd soundcore rfkill sg cpufreq_dt sch_fq_codel ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid0 multipath linear raid1 md_mod realtek rockchipdrm analogix_dp dw_hdmi dwmac_rk dw_mipi_dsi stmmac_platform drm_kms_helper stmmac cec mdio_xpcs rc_core drm drm_panel_orientation_quirks
[ 18.003239] CPU: 1 PID: 591 Comm: cached_setup_fo Tainted: G C 5.8.16-rockchip64 #20.08.14
[ 18.003241] Hardware name: Pine64 RockPro64 v2.1 (DT)
[ 18.003246] pstate: 00000085 (nzcv daIf -PAN -UAO BTYPE=--)
[ 18.003261] pc : ahci_single_level_irq_intr+0x24/0x90
[ 18.003278] lr : __handle_irq_event_percpu+0x60/0x2a8
[ 18.053720] sp : ffff800011aa3e40
[ 18.053722] x29: ffff800011aa3e40 x28: ffff8000114de018
[ 18.053726] x27: ffff0000f5a8e000 x26: ffff8000114de018
[ 18.053729] x25: ffff8000117fa1c0 x24: ffff800011aa3f04
[ 18.053733] x23: 0000000000000000 x22: 00000000000000e8
[ 18.053737] x21: ffff800011cd5008 x20: ffff0000f5a55200
[ 18.053740] x19: ffff0000f671c200 x18: 0000000000000000
[ 18.053748] x17: 0000000000000000 x16: 0000000000000000
[ 18.094273] x15: 0000000000000000 x14: 0000000000000a70
[ 18.094277] x13: 0000000000000a70 x12: 0000000000000018
[ 18.094280] x11: 0000000000000040 x10: ffff80001181e690
[ 18.094283] x9 : ffff80001181e688 x8 : ffff0000f68c8dd8
[ 18.094286] x7 : 0000000000000000 x6 : 0000000000000000
[ 18.094290] x5 : ffff0000f68c8db0 x4 : ffff0000f68c8f18
[ 18.094294] x3 : ffff8000114de018 x2 : ffff800010955938
[ 18.094297] x1 : ffff0000f598fc80 x0 : 00000000000000e8
[ 18.136707] Call trace:
[ 18.136714] ahci_single_level_irq_intr+0x24/0x90
[ 18.136717] __handle_irq_event_percpu+0x60/0x2a8
[ 18.136720] handle_irq_event_percpu+0x34/0x90
[ 18.136725] handle_irq_event+0x48/0xe8
[ 18.136730] handle_fasteoi_irq+0xcc/0x180
[ 18.136735] generic_handle_irq+0x30/0x48
[ 18.136744] __handle_domain_irq+0x94/0x108
[ 18.177317] gic_handle_irq+0x60/0x158
[ 18.177322] el1_irq+0xb8/0x180
[ 18.177329] __mod_lruvec_state+0x7c/0x128
[ 18.177334] page_remove_rmap+0xd0/0x518
[ 18.177343] unmap_page_range+0x4d4/0xbc0
[ 18.203146] unmap_single_vma+0x88/0x118
[ 18.203149] unmap_vmas+0x70/0xe8
[ 18.203153] exit_mmap+0xc8/0x180
[ 18.203157] mmput+0x84/0x158
[ 18.203166] begin_new_exec+0x2d0/0xab0
[ 18.226190] load_elf_binary+0x39c/0x16b8
[ 18.226193] __do_execve_file.isra.0+0x520/0x9f8
[ 18.226196] __arm64_sys_execve+0x44/0x58
[ 18.226200] el0_svc_common.constprop.0+0x70/0x188
[ 18.226202] do_el0_svc+0x24/0x90
[ 18.226207] el0_sync_handler+0x90/0x198
[ 18.226215] el0_sync+0x158/0x180
[ 18.260378] Code: a9025bf5 f9401021 f9400835 910022b5 (b94002b3)
[ 18.260391] ---[ end trace 3fd32674691543d2 ]---
[ 18.260399] Kernel panic - not syncing: Fatal exception in interrupt
[ 18.277167] SMP: stopping secondary CPUs
[ 18.279589] Kernel Offset: disabled
[ 18.279592] CPU features: 0x240022,2000600c
[ 18.279594] Memory Limit: none
[ 18.292913] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
Any thoughts? I know I'm just yelling into the void here, but is there something I'm doing wrong?
Won't boot with SATA card - by rjzak - 10-12-2020, 05:23 PM
RE: Won't boot with SATA card - by rjzak - 10-18-2020, 11:37 AM
RE: Won't boot with SATA card - by rjzak - 10-18-2020, 01:44 PM
RE: Won't boot with SATA card - by rjzak - 10-30-2020, 03:12 PM
RE: Won't boot with SATA card - by kuleszdl - 01-09-2021, 05:56 PM
  No audio on HDMI after u-boot upgrade xlx 2 1,931 11-28-2023, 01:03 PM
  AW-CM256SM wifi card mtek 4 2,372 10-30-2023, 12:00 PM
Last Post: diederik
  Which SATA card should I use my NAS server RAID5 Louysa 3 917 09-24-2023, 04:40 AM
Last Post: JPT223
  SATA keeps crashing JPT223 1 568 09-21-2023, 10:52 PM
  SATA hotplug not working? JPT223 0 447 09-15-2023, 04:20 AM
Last Post: JPT223
  RP64 Won't Boot After Power Down ColPanic_ 10 7,845 06-27-2023, 07:31 AM
Last Post: dkebler
  Compatible PCIe Sata Controller spacebricker 1 1,580 02-06-2023, 10:03 AM
Last Post: diizzy
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,942 12-18-2022, 06:25 PM
Last Post: heyghoge
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,388 12-31-2021, 12:53 AM
Last Post: publiclewdness
  Existings disks and using a StarTech SATA Controller jkugler 1 2,092 12-09-2021, 06:41 AM
Last Post: SVDSHRDJD
