RockPro64 has bad Memory (Software sogfaults and kernel panics)
(11-25-2020, 04:42 AM)n4tter4ngell Wrote: I'm booting Debian stable, based on the official debian unstable installer image. It does not include Rockchip binary blobs in u-boot. I roughly outlined my approach here.
Thanks for this idea, I gather that you're following this:
https://www.kulesz.me/post/140-debian-de...4-install/
I found your comment detailing the differences in your procedure:
http://forum.pine64.org/showthread.php?t...1#pid82701
This looked promising, but fairly involved, so I decided to try your second option.
(11-25-2020, 04:42 AM)n4tter4ngell Wrote: You could also try the u-boot version made by sigmaris, which also is build from mainline u-boot (without Rockchip blobs). Read the first post he made, there are links to emmc/SD-card version you could try, so no need to flash SPI to test this out.
Thanks for the pointer to this, seems like sigmaris has been doing some great work. I used dd to install mmc_idbloader.img and mmc_u-boot.itb from https://github.com/sigmaris/u-boot/relea...ckpro64-ci to my sdcard. It was really nice to see output from the bootloader on the display, and my armbian/debian server image booted fine with this bootloader.
In less than 5 min memtester has already produced many errors. Since this test has eliminated the blob overwriting memory as a potential cause, I'll proceed with the RMA process.
Thanks for your help!
RE: RockPro64 has bad Memory (Software sogfaults and kernel panics) - by BinaryMan32 - 11-27-2020, 05:49 PM
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,054 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 909 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 25,893 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 856 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 1,644 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 6,713 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,158 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 5,439 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 2,177 05-27-2022, 06:51 PM
Last Post: justwantin
  charging 3 rockpro64 from single source rpt312 1 1,754 05-16-2022, 02:34 AM
Last Post: dukla2000
