Android 9.0 and Pluto on Rock64-1G
Hey all,
I'm currently trying to get a 1GB R64 up and running with the Rooted Android 9.0 image and things have been going pretty well, but I do have an issue I'd like to cover here before I try to make any serious changes and that issue is with the Pluto TV app.
 Let me first explain that I already have the PlutoTV app installed on a 1GB R64 with the Android 8.0 image. I installed PlutoTV onto it from the Google Play store, which I installed through the ADB, as suggested in another post on this board.
My current project is the 1G-Rock64 with the following
Image: ROCK64_dd_20190618_stock_rooted_android_9.0_emmcboot-16GB.img.gz (using Etcher to program 16GB eMMC)
Google Play Services: version 20.36.15 (080406-333172415)
Google Services Framework: Ver: 9-6475783
Google Play store Ver: 21.9.47-21[0][PR]331897675
At this point everything seems to be working well, as Play store works. I also had to figure out to unplug the keyboard and use the on screen keyboard to input the wireless password but the apps I've tried so far work. Except for Pluto.
Pluto, as loaded from the Play store gives the following error:
 INCOMPATIBLE VERSION
The installed APK is not compatible with this device. Please download a supported version from Google Play.
My question(s) are: Has anyone else had this issue with this app, on this image? Could this be an issue with the image, or that it's not the AndroidTV version? Should I load the un-rooted image (ROCK64_dd_20190617_stock_android_9.0_emmcboot-16GB.img.gz ) to correct this issue? I truly don't mind having to reload this card with another image, the question is more about saving myself a bit of time testing another image, because this one had been going well so far.
Sincerely,
Deanne
Android 9.0 and Pluto on Rock64-1G - by missdeenola - 09-27-2020, 02:57 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,274 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,033 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,558 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,607 05-04-2021, 01:58 AM
Last Post: zet_lab
  broken android microsd images jbach50 1 3,504 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,020 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,580 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,729 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,812 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 6,556 09-09-2020, 08:26 AM
Last Post: BowerR64
