USB-C Charging on the PBP?
#20
(09-29-2020, 11:28 AM)MtnSk8 Wrote: Power supply specs from the wiki  "USB-C 5V, 15W PD quickcharge" seems incorrect. If it's fixed at 5V then it's not "PD".  Dodgy
K, the first time I actually played along with this, the second time I just kept quiet, but now I'm actually getting a bit annoyed...
Without PD USB can deliver up to six unit loads for high power SuperSpeed devices, where the unit load is 150mA on USB 3.0 (SuperSpeed) and 250mA for multi-lane SuperSpeed. That means without PD USB can deliver up to 7.5W. USB PD was developed specifically to standardize the way to deliver more than 7.5W of power, and than includes 15W, the maximum power deliverable without increasing voltage. So technically 15W delivery in PBP is USB PD, compliant with revision 2 or 3 of the standard, though saying "quickcharge" is indeed a bit of a misnomer since that would imply a different proprietary technology by Qualcomm that predates USB PD standard and AFAIK is available only on their Snapdragon platform.
That said, IMNSHO 15W is barely adequate for PBP.
This message was created with 100% recycled electrons
USB-C Charging on the PBP? - by Paulie420 - 09-24-2020, 09:13 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-24-2020, 09:52 PM
RE: USB-C Charging on the PBP? - by jiyong - 09-25-2020, 05:12 AM
RE: USB-C Charging on the PBP? - by as400 - 09-25-2020, 05:25 AM
RE: USB-C Charging on the PBP? - by wdt - 09-25-2020, 09:11 AM
RE: USB-C Charging on the PBP? - by as400 - 09-28-2020, 07:07 AM
RE: USB-C Charging on the PBP? - by Paulie420 - 09-25-2020, 10:53 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-25-2020, 06:46 PM
RE: USB-C Charging on the PBP? - by jiyong - 09-25-2020, 05:28 PM
RE: USB-C Charging on the PBP? - by bastafari - 09-26-2020, 09:49 AM
RE: USB-C Charging on the PBP? - by xmixahlx - 09-26-2020, 10:37 AM
RE: USB-C Charging on the PBP? - by Paulie420 - 09-26-2020, 12:03 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-27-2020, 12:14 AM
RE: USB-C Charging on the PBP? - by lot378 - 09-28-2020, 07:28 AM
RE: USB-C Charging on the PBP? - by as400 - 09-28-2020, 08:39 AM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-29-2020, 11:28 AM
RE: USB-C Charging on the PBP? - by bastafari - 09-29-2020, 12:25 PM
RE: USB-C Charging on the PBP? - by bastafari - 09-29-2020, 05:32 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-29-2020, 09:50 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-30-2020, 04:16 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-30-2020, 11:26 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-29-2020, 04:48 PM
RE: USB-C Charging on the PBP? - by Idaho - 09-30-2020, 01:05 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 10-01-2020, 09:00 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 10-02-2020, 09:02 AM
RE: USB-C Charging on the PBP? - by wdt - 10-01-2020, 11:03 AM
RE: USB-C Charging on the PBP? - by as400 - 10-02-2020, 02:33 AM
RE: USB-C Charging on the PBP? - by lot378 - 10-02-2020, 10:08 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 10-02-2020, 04:20 PM
RE: USB-C Charging on the PBP? - by wrzomar - 12-04-2020, 02:39 PM
RE: USB-C Charging on the PBP? - by xyzzy - 12-07-2020, 05:08 AM
RE: USB-C Charging on the PBP? - by wrzomar - 12-11-2020, 01:06 PM
RE: USB-C Charging on the PBP? - by xyzzy - 12-11-2020, 02:41 PM
RE: USB-C Charging on the PBP? - by wrzomar - 12-12-2020, 02:20 PM
Photo P{inebook Pro not charging Ome Ko 6 2,113 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 7,040 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,636 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,392 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,885 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,672 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,974 01-25-2021, 08:48 PM
Last Post: bchenlee609
  Charging via USB-C Port tyha 15 20,382 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,182 05-30-2020, 06:05 PM
  Charging via USB GloriousCoffee 7 8,793 04-03-2020, 12:01 PM
Last Post: GloriousCoffee
