Pinebook Pro Boot Issues - Booting needs multiple attempts
(10-03-2020, 10:11 PM)wdt Wrote: Well, there are at least 4  (slightly) different debian images, this is aarch64 kernel and armhf userland,,
so somewhat unique,,  obviously quite good for 32 bit arm apps
I actually have that on my emmc, for reasons, but that is NOT what I recommended to you
I said "rescue SD",, on 8-16G SD, not necessarily highest quality SD,,, do update it (mrfixit_update.sh,when booted from SD)
Then, it is very easy to put that uboot on emmc
In short, using dd,, save emmc mbr,, maybe save 1st 16M,, dd 1st 16m SD->emmc,, restore mbr
This takes literally 5 minutes (or less), also, an OK rescue SD, and good for 32 bit arm apps
The uboot (trust) is good for sleep BTW, it is a bsp uboot, the distro, not at all
Oh, I realized that i didn't say, yes that is the right image
Do you need me to explain the dd commands to you?
I can run dd, that's my preferred method for "burning" disk images.
Can you explain the difference from the boot image on the mrfixit disk image and the uboot-pinebookpro-bsp I installed earlier? How can it fix the garbled screen after soft reboot issue and the bsp image cannot? As far as linux experience, I'm fairly intermediate and I haven't had to deal with booting issues yet. I run Manjaro KDE and Arch on my x86 based desktop and laptop and booting has always just "worked". Would you happen to know if the Manjaro folks plan to create a boot image that fixes the soft reboot issue? Maybe I should report this issue on the Manjaro forum as well?
Thanks for all your help btw!
RE: Pinebook Pro Boot Issues - Booting needs multiple attempts - by mtndew - 10-04-2020, 01:41 AM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 655 05-06-2024, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 367 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 310 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 654 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,155 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,282 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 6,091 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,505 12-27-2022, 03:31 PM
Last Post: samtux
  Touchpad Issues - August 2022 Run SteveCaruso 5 3,023 12-14-2022, 11:00 PM
Last Post: doug
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,635 11-30-2022, 04:28 PM
