All the Manjaro Builds!
(10-01-2020, 08:35 AM)Cree Wrote:
(09-30-2020, 05:33 PM)hiimtye Wrote: I tried the lomiri Alpha 1 and it is super snappy, which I expected as that was my experience with UBPorts, but it's a hopelessly closed system. there doesn't look to be any work to even port over libertine to get X11 apps working, and there's only like 8 apps (weather crashes, and the calendar doesn't even get added to the menu. I haven't found any other method of finding apps that work in lomiri, other than a pacman -Ss lomiri
installing an X11 app (for instance, Firefox) results in some weird split window thing where one window is the title of the app, and the other window is titled /usr/lib/appname and both are empty.
this might be a viable solution if there were more apps, and/or Anbox worked in it.
Isnt the issue of being a closed system a ubports issue, and lomiri just a ui/de? I figured it would be much more open on top of Manjaro. Maybe just that some features required for it to function openly havent yet been tweaked by the manjaro team since porting lomiri from UB touch.
Correct me if im wrong.
Should be less of an issue with Manjaro Lomiri because the file browsing app called Index works as well as a few others.
All the Manjaro Builds! - by Cree - 09-22-2020, 09:59 AM
RE: All the Manjaro Builds! - by Potts - 09-23-2020, 10:38 AM
RE: All the Manjaro Builds! - by hiimtye - 09-24-2020, 04:54 PM
RE: All the Manjaro Builds! - by hiimtye - 09-30-2020, 05:33 PM
RE: All the Manjaro Builds! - by Cree - 10-01-2020, 08:35 AM
RE: All the Manjaro Builds! - by DrewTechs - 10-04-2020, 10:49 PM
RE: All the Manjaro Builds! - by preflex - 10-06-2020, 04:28 AM
RE: All the Manjaro Builds! - by bcnaz - 09-30-2020, 09:35 PM
RE: All the Manjaro Builds! - by zetabeta - 10-01-2020, 12:56 AM
RE: All the Manjaro Builds! - by hiimtye - 10-02-2020, 02:06 AM
RE: All the Manjaro Builds! - by LinAdmin2 - 10-02-2020, 06:36 AM
RE: All the Manjaro Builds! - by firefox-58 - 10-02-2020, 08:25 AM
RE: All the Manjaro Builds! - by cefre00 - 10-09-2020, 05:33 PM
  Manjaro: Settings doesnt open nbh 0 619 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,646 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,660 05-10-2023, 09:27 PM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 836 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,939 03-02-2023, 07:25 PM
  Can't install Manjaro thorensjubilee 1 1,060 02-09-2023, 08:17 AM
  Manjaro plasma-mobile Beta 13 Uturn 13 5,040 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,615 11-22-2022, 05:00 PM
Last Post: Chief
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,092 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 2,544 09-05-2022, 03:42 PM
Last Post: nroth
