With what image(s) does phoning fully work?
(09-21-2020, 12:18 AM)MiSimon Wrote:
(09-20-2020, 06:37 AM)LinAdmin2 Wrote: I have now spent a lot of time trying to find an image where incoming and outgoing phone calls do work with decent sound quality.
I am either too dumb or it must be kind of a lottery to find such images.
Can  somebody post here URLs of downloadable images where phoning works as on a commercial phone?
Many thanks!
For me (Austria, carrier: "3") my pmos ce phone had working calls (only tested 4G) and sms (4G and 3G) after unboxing and installing the available updates.
The audio quality is definitely an issue, but it is usable.
Mobian (image from last friday) also had working calls (only tested 4G) and sms (4G and 3G) but the audio quality was worse then on pmos, i could hardly hear what the other person was saying.
Thank you for the detailed answer. It looks intriguing that there are so many differences observed between the delivered postmarketOS phones, even when using the same software.
With the delivered software, my phone could call others and ringed when others called, but the sound was not understandable.
Your post motivated me to upgrade the installed software. Despite my fears of bricking the software the installation ran smooth and upgraded 50 packages.
I was very happy and hoped, that now the sound bug would be fixed. The disappointment followed immediately: Now the phone does no longer call others and when others call there is no ringing and the callers get notified that their call was not accepted...
RE: With what image(s) does phoning fully work? - by LinAdmin2 - 09-21-2020, 08:08 AM
  Is it normal for the pinephone to "discharge" after fully charged on multiple OS? Shad190 2 1,004 05-10-2023, 10:37 PM
Last Post: Shad190
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 248,244 03-05-2023, 11:04 AM
Last Post: Eugo
  PureTalk work with Pinephone? car46999 6 3,038 01-30-2023, 12:05 AM
Last Post: car46999
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 1,317 05-21-2022, 03:03 PM
Last Post: zetabeta
  SD nonfunctional, how is support supposed to work? slomobile 6 4,126 01-18-2022, 07:02 PM
Last Post: slomobile
  Best OS where most of the things work? themagicm 13 10,384 12-09-2021, 07:28 PM
Last Post: ryo
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 1,437 11-07-2021, 10:15 AM
Last Post: beta-user
  Can't mount eMMC image on my desktop? nelstomlinson 0 1,322 10-16-2021, 09:30 AM
Last Post: nelstomlinson
  Lets discuss the GPS. Who has got it to work? AwHereWeGoAgain 8 6,512 09-17-2021, 01:29 PM
Last Post: KNERD
  What OS will actually work with phone calls? Nutmeg 16 12,369 08-07-2021, 11:01 AM
Last Post: mouffa
