Soft restart doesn't work
>Question: would changing the label on the SD make it bootable?
Probably
boot emmc,,,,lsblk,,, line with "/" is emmc,, so you know which blk is which (mmcblkX, what is "X")
when I say /dev/SD, replace with right mmcblkX (sorry, since is in carrier, SD is /dev/sda, lots simpler)
all as root/sudo
dosfslabel /dev/sda1 BOOT_MNJ_SD (BOOT_MNJ_SD is 11 chars, so won't be truncated,,
also UPPER CASE so if case is changed behind your back, won't matter,,1st partition)
e2fslabel /dev/sda2 root_fs_mnj_sd (2nd partition)
edit/change /mnt/sda2/etc/fstab and /mnt/sda1/extlinux/extlinux.conf to have these names
(whatever /mnt/?? is, rootfs on SD for fstab (sda2), boot for extlinx.conf (sda1))
Takes more time to type than do
And BTW,, perhaps a "pro" tip,, since it is hard to put a physical label on a uSD,, too small
cd / (of SD) sudo touch This-is-$DISTRO-VERSION-SD,,, replace distro-version with appropriate
Then ls /,,, you don't have to dig thru etc to find out just what is this
--edit--
Sorry, read too fast, since SD is in carrier, it is /dev/sda,, makes it a lot easier
so dosfslabel /dev/sda1 whatever
e2label /dev/sda2 whatever
Perhaps use applet by clock to unmount , unplug, replug, will have new names, remount
mount |grep sda to see where they are mounted for editing fstab, extlinux
OR,, since I see are UUIDs are different, could mount by UUID rather than label, but still could be confusing for YOU,
which is which? (when not in carrier)
Soft restart doesn't work - by dgkPBP - 09-16-2020, 03:01 PM
RE: Soft restart doesn't work - by wdt - 09-16-2020, 10:29 PM
RE: Soft restart doesn't work - by dgkPBP - 09-17-2020, 05:11 AM
RE: Soft restart doesn't work - by wdt - 09-17-2020, 08:31 AM
RE: Soft restart doesn't work - by dgkPBP - 09-17-2020, 01:38 PM
RE: Soft restart doesn't work - by wdt - 09-17-2020, 04:12 PM
RE: Soft restart doesn't work - by dgkPBP - 09-18-2020, 06:32 AM
RE: Soft restart doesn't work - by wdt - 09-18-2020, 02:56 PM
RE: Soft restart doesn't work - by dgkPBP - 09-19-2020, 06:56 AM
RE: Soft restart doesn't work - by wdt - 09-19-2020, 09:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,377 12-15-2023, 02:11 PM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,984 08-03-2023, 03:30 PM
  Doesn’t power on after flashing emmc badguru 3 1,307 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC for Odroid C4 work in PBP? dieselnutjob 6 3,507 04-05-2022, 10:10 AM
Last Post: jiyong
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,783 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  NVMe doesn't show up Seferi 19 17,613 10-30-2020, 07:08 AM
Last Post: ReddestDream
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,604 09-29-2020, 10:24 PM
  Trackpad doesn't pick up small movements dieselnutjob 3 4,483 07-15-2020, 06:18 AM
Last Post: dieselnutjob
  Does Fastboot Devices tools work on Pinebook Pro? pinejolla 6 7,589 06-16-2020, 03:14 AM
Last Post: FeMike
  How do the kill switches work? Stevie-O 7 9,328 06-01-2020, 11:34 AM
Last Post: Phillip Bell
