Trackpad doesn't pick up small movements
My Pinebook Pro arrived two days ago and it's great, however I have noticed that if I want to move the mouse pointer just a couple of pixels away from where it is that it's basically impossible.
Small movements don't move the pointer at all.
If I put my finger on the trackpad and very slowly move it in any direction it's like, nothing, nothing, nothing, it's moving!
Is this a configuration thing with Manjaro?  does it need a firmware update?
thanks DNJ
Hi.
The answer is probably both.
There is a wiki paragraph about config that improves the trackpad.
However it also seems that the trackpad firmware is another limiting factor.
Some people had a look already and try to reverse engineer the trackpad behavior, however due to the technical setup there are challenges.
The trackpad is kind of sitting on top of the keyboard. You need to control the keyboard first and then through another bus get to the trackpad..
So I would suggest to have a look at the wiki first. My mouse is working quite ok. But I also know what you mean with difficulties for very small movements.
Be sure to update to the last firmware (unofficial if you need corrected fn+F9 -> F12 and super+arrows key combination : https://github.com/jackhumbert/pinebook-...rd-updater )
Also, if you want to be precise, dont move your finger, just lean it, it works for me.
I did step-1, step-2 and default_iso.hex okay, and it survived.
It does seem better, maybe.
I also turned down the anti noise down to zero in the KDE trackpad settings before, but the firmware does seem better.
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,198 12-15-2023, 02:11 PM
  Doesn’t power on after flashing emmc badguru 3 1,240 02-25-2023, 09:00 PM
Last Post: badguru
  Trackpad firmware update Luke 263 359,860 07-28-2021, 12:52 PM
Last Post: Luke
  Trackpad film clockcycles 5 5,054 06-18-2021, 09:34 PM
  Lifting Trackpad p3pp3r 7 9,517 03-23-2021, 05:48 PM
Last Post: Timpanogos Slim
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,751 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  No keyboard & trackpad leads to no display. RMA from the US. Free parts in Seattle BitterPine 4 8,536 12-30-2020, 06:14 AM
Last Post: BetteHoward
Lightbulb Future Upgrade Options? a 'small' request Lyrixcaz 10 8,615 12-11-2020, 01:05 AM
  NVMe doesn't show up Seferi 19 17,243 10-30-2020, 07:08 AM
Last Post: ReddestDream
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 13,284 09-29-2020, 10:24 PM
