in search for the /boot/config-...... file
if kernel does not include PREEMPT try this,
$ sudo apt-get install linux-lowlatency
not sure if that will fix it in ubuntu, but your goal is to have a low latency kernel
also, you should start reading about kernels and this fellows guide. perhaps sending him emails will help.
but he did mention this,
Note: Ubuntu/Debian can set up a properly configured audio group for you when you install jackd2. If you'd like, you can do this before continuing:
$ sudo apt-get install jackd2
have you done that yet?
RE: in search for the /boot/config-...... file - by dkryder - 05-25-2016, 08:25 AM
  Pine 1 will no longer boot (bricked) dstallmo 0 1,339 06-22-2023, 12:22 PM
Last Post: dstallmo
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 3,089 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 4,212 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 2,844 03-23-2019, 04:06 AM
Last Post: ktaragorn
  Resize /Boot mmcblk0p1 on SD? chadc 7 11,326 08-24-2018, 01:23 PM
Last Post: goathunter
  Ubuntu boot very slow with wifi driver remainder 9 21,010 08-03-2017, 07:23 AM
Last Post: victorssantos
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 4,738 02-22-2017, 06:50 AM
Last Post: MarkHaysHarris777
  Need help with boot options Gnx 1 3,466 01-22-2017, 09:27 PM
  straight boot into desktop Ola 2 3,875 08-01-2016, 11:12 PM
Last Post: Ola
  UBUNTU first boot Clouddead 6 7,236 06-29-2016, 12:40 PM
Last Post: pineacle
