LCD Touch Screen Problem.
(05-23-2016, 02:36 PM)Gavin Wrote: What I have:
The pine A64 board.
LCD Touch Screen
San Disk 32gb microSD card
Power = 2.4AMP
I tried all the pins, and the LCD just stays white. The pine board works fine with hdmi.
Do I not have enough power to power the LCD or is it something else?
I have also booted Android 5.1.1 at least once.
Number one probable cause why LCD turns bright without image, its because theres a problem with your physical connection from your pine board to the LCD.I got this problem before and solved it by changing the orientation extension board (small board that has only two connectors that links between the LCD ribbon and the main board ribbon).
LCD Touch Screen Problem. - by Gavin - 05-23-2016, 02:36 PM
RE: LCD Touch Screen Problem. - by Ghost - 05-23-2016, 03:27 PM
RE: LCD Touch Screen Problem. - by Gavin - 05-23-2016, 03:38 PM
RE: LCD Touch Screen Problem. - by Ghost - 05-23-2016, 03:45 PM
RE: LCD Touch Screen Problem. - by tllim - 05-23-2016, 11:43 PM
RE: LCD Touch Screen Problem. - by tkaiser - 05-24-2016, 07:21 AM
RE: LCD Touch Screen Problem. - by michaelquezon - 11-27-2016, 10:26 PM
  7 inch LCD touch panel is upside down? joshpl 2 1,727 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 3,128 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 35,487 07-21-2017, 07:41 AM
Last Post: apple4ever
  [Problem] help find R110~R113 resistors on board to LCD Rotation 180deg msmmbl 2 3,890 07-21-2017, 12:00 AM
Last Post: msmmbl
  I2C Touch Panel mbt28 0 2,143 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD screen brightness/contrast Learnincurve 10 13,982 02-17-2017, 12:45 PM
Last Post: psychedup
  LCD touch panel emits low power Naccies 4 6,317 01-09-2017, 07:45 PM
  Touch screen support shariq_2001 14 20,010 12-07-2016, 07:47 AM
Last Post: Luke
  Screen flashes blue and then goes dark. tanarri 5 7,755 06-22-2016, 10:53 AM
Last Post: tanarri
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 5,127 06-13-2016, 08:24 AM
Last Post: PapaStahl
