LCD Touch Screen Problem.
(05-23-2016, 02:36 PM)Gavin Wrote: The pine A64 board.
LCD Touch Screen
You would need the appropriate driver for this type of SPI devices to get a simple framebuffer device (forget about the other answers, especially HDMI and the totally different Pine64 LCD module): https://github.com/notro/fbtft/wiki
That means a patch like this has to applied to kernel sources (this patch is against another 3.10.y kernel but a 32-bit variant so it might require some tweaks). And then you should keep in mind that the fps of such an SPI display are pretty low so in case you want to use an LCD that is fully useable (or you have no experience in compiling Linux kernels or just want to run Android) there is no alternative to the official LCD.
TL;DR: In Pine64's current state (kernel drivers, support 'quality' by moderators here in the forum) you can forget about using any cheap/small SPI display with this board.
LCD Touch Screen Problem. - by Gavin - 05-23-2016, 02:36 PM
RE: LCD Touch Screen Problem. - by Ghost - 05-23-2016, 03:27 PM
RE: LCD Touch Screen Problem. - by Gavin - 05-23-2016, 03:38 PM
RE: LCD Touch Screen Problem. - by Ghost - 05-23-2016, 03:45 PM
RE: LCD Touch Screen Problem. - by tllim - 05-23-2016, 11:43 PM
RE: LCD Touch Screen Problem. - by tkaiser - 05-24-2016, 07:21 AM
RE: LCD Touch Screen Problem. - by michaelquezon - 11-27-2016, 10:26 PM
  7 inch LCD touch panel is upside down? joshpl 2 1,848 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 3,144 12-07-2019, 06:50 PM
Last Post: kodachrome
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 35,691 07-21-2017, 07:41 AM
Last Post: apple4ever
  [Problem] help find R110~R113 resistors on board to LCD Rotation 180deg msmmbl 2 3,917 07-21-2017, 12:00 AM
Last Post: msmmbl
  I2C Touch Panel mbt28 0 2,154 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD screen brightness/contrast Learnincurve 10 14,053 02-17-2017, 12:45 PM
Last Post: psychedup
  LCD touch panel emits low power Naccies 4 6,374 01-09-2017, 07:45 PM
  Touch screen support shariq_2001 14 20,134 12-07-2016, 07:47 AM
Last Post: Luke
  Screen flashes blue and then goes dark. tanarri 5 7,818 06-22-2016, 10:53 AM
Last Post: tanarri
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 5,160 06-13-2016, 08:24 AM
Last Post: PapaStahl
