POCSAG Pinephone Hardware Add-On; Radio Silence, Privacy, Anonymity,and Freedom
#19
I am looking at this IC PCF5001T
pdf.datasheetcatalog.com/datasheet/philips/PCF5001T.pdf
chosen based mostly on availability, I think the DI(pin 17) will work with the digital out pin from the HopeRF RFM23BPW.
The POCSAG controller has a read cycle pin which should be able to trigger wake/rx on the hopeRF IC so we might be able to save some W/h.
Thoughts?
I would LOVE to find a cheap breakout SM PCB for SOT136 packages so I don't have to hand micro-solder with magnet wire this PCF5001 and glue it down onto a perfboard.
I am assuming the Pinephone add-on is going to be a 433mhz??  It looks like I can tune the hoperf module to commercial and amateur radio 400-500 mhz area paging freqs though I hope it will work with the band passes on the board though we can bypass and change if required.
RE: POCSAG, Radio Silence, and Freedom - by tllim - 09-05-2020, 06:21 PM
RE: POCSAG, Radio Silence, and Freedom - by bcnaz - 09-05-2020, 07:45 PM
RE: POCSAG, Radio Silence, and Freedom - by tllim - 08-07-2021, 10:25 PM
RE: POCSAG, Radio Silence, and Freedom - by tllim - 08-09-2021, 09:28 PM
RE: POCSAG Pinephone Hardware Add-On; Radio Silence, Privacy, Anonymity,and Freedom - by biketool - 08-25-2021, 07:34 AM
  Case for Pinephone totilele 13 7,260 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 640 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,178 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 452 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 519 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,024 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,374 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,038 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,470 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 637 08-04-2023, 10:47 PM
Last Post: jnpine
