SD card wrong space
(08-31-2020, 03:56 PM)z4v4l Wrote: that would be a "better" option if one wants to destroy his/her NTFS volume and all the data it holds. for others, - just don't do that.
Installing, say, Ubuntu on a disk that already contains Windows usually works fine. There is a risk of course, any time you move around or resize partitions. Make sure you have a backup.
(08-31-2020, 03:56 PM)z4v4l Wrote: for the OP - after you flashed your SD card with the OS image for running on Pinephone, you should not use it elsewhere.
There is nothing wrong with using the SD card elsewhere. Just use it with systems that can handle the file system that's on the card.
It's practical to do the same with USB memory sticks - install a live linux image to it, and then use the card for both storage and as a generic boot stick. Both types of devices are just block devices and you can use any partition type and file system type(s) you'd like on them.
SD card wrong space - by Cree - 08-31-2020, 10:59 AM
RE: SD card wrong space - by bitnick - 08-31-2020, 03:30 PM
RE: SD card wrong space - by z4v4l - 08-31-2020, 03:56 PM
RE: SD card wrong space - by bitnick - 08-31-2020, 08:10 PM
RE: SD card wrong space - by z4v4l - 09-01-2020, 02:41 PM
RE: SD card wrong space - by bitnick - 09-01-2020, 07:22 PM
  Wrong GPS Position derbaertigefrytz 1 976 09-03-2023, 02:43 PM
Last Post: alaraajavamma
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,374 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,505 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,055 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,301 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 1,844 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,636 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 4,025 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Strange SD Card Problems anhilde 7 6,469 02-21-2021, 07:52 AM
  Fastest SD card happybot-4678 9 8,682 02-20-2021, 01:08 AM
Last Post: dsimic
