Strange SD Card Problems
I have Problems with SD card flashing that I cannot explain. Basically I have run Raspis for years, am comfortable with command line (Developer), have written lots of images to SD cards and mostly things worked as expected. Up to my pinephone. Basically I download images and write them to a 16GB card with dd like such:
/mnt/cloud/images# dd bs=128K if=Manjaro-ARM-phosh-pinephone-beta5.img of=/dev/sdd conv=fsync status=progress
On this one 16GiB card that I have lying around I can successfully do this with Manjaro Posh/KDE Images, Mobian and Arch for Arm. All work as expected. Now I have a bunch of 32GiB cards I'd like to use. But writing to those cards with the same dd command will result in boot failure. The LED on the pinephone turns red and that is iit. I have tried zeroing out the cards before write, bought new ones. None of the 32GiB cards work. I tried using different SD card readers etc. Nothing works. Except the trusty old 16Gib Sandisk Card. The 32Gib Cards are SanDisk and Transcend cards. If I flash for example Manjaro KDE, I get sensible values (to me) when checking the card with sfdisk like:
sfdisk -uS -d /dev/sdf
label: dos
label-id: 0x198aa440
device: /dev/sdf
unit: sectors
/dev/sdf1 : start=      62500, size=      437501, type=c
/dev/sdf2 : start=      500001, size=    9617119, type=83
The start sector of looks to be a bit far into the card, but it is the same as in the image:
fdisk -l Manjaro-ARM-plasma-mobile-pinephone-beta2.img
Disk Manjaro-ARM-plasma-mobile-pinephone-beta2.img: 4.8 GiB, 5174722560 bytes, 10106880 sectors
Disklabel type: dos
Disk identifier: 0xdc868f53
Device                                        Boot  Start      End Sectors  Size Id Type
Manjaro-ARM-plasma-mobile-pinephone-beta2.img1      62500  500000  437501 213.6M  c W95 FAT32 (LBA)
Manjaro-ARM-plasma-mobile-pinephone-beta2.img2      500001 10106879 9606879  4.6G 83 Linux
Any help or pointer would be really appreciated as to what could be the reason for this. Next stop is getting a UART Adapter so I can see what the bootloader is doing I guess.
Best Regards,
anhilde
I finally managed to boot from a 32GB card. How did I do it? First I wrote the image to a new card. It did not boot... Then I tried again, this time pressing on the SD slot from the outside. I will check with my calipers later if that old 16GB card is actuall slightly thicker than the new ones...
(02-18-2021, 11:34 AM)anhilde Wrote: I finally managed to boot from a 32GB card. How did I do it? First I wrote the image to a new card. It did not boot... Then I tried again, this time pressing on the SD slot from the outside. I will check with my calipers later if that old 16GB card is actuall slightly thicker than the new ones...
That does sound a bit odd. But sdcards are finnicky ime.
Try overwriting it with random data instead of /dev/zero.
Use:
sudo dd if=/dev/urandom of=/dev/mmcblk0 bs=8M status=progress
After doing the above random overwrite, flash your image again. If the card is still alive it should work (not the same longevity as other storage). I had an issue where overwriting with 0's booted the previous OS, or wouldn't boot. Since using /dev/urandom I have had no problems, and for one reason or another, seems to fix most sdcard issues others have had.
Hope this helps. Smile
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
Thanks, I will try random instead of zeros. Seems that it was not the pressing on the slot. I tried once again writing an image. First try, booting failed, tried again, booting failed again. Then restarted my laptop without cardreader attached (thinkpad t420s) and wrote the same image once again and then it booted. Not sure if is coincidence, but I do remember restarting my laptop before the previous successful attempt. I do not understand how this could affect the write though. Perhaps it is just coincidence.
Best Regards,
anhilde
Are you referring to the slot in your laptop or card reader, or to the slot in your PinePhone?
Assuming these 32GB cards are new, have you tested them?  Counterfeits are so rampant, we had to put some information in our Wiki about it.[0]
[0] I come from Armbian, which is why I am very familiar with our links / wiki as well as common problems.  If there are similar resources here I have just not found them yet, still learning my way around Pine docs / wiki, etc.
Cheers,
TRS-80
Protocols, not Platforms
I refer to the slot on the pinephone.
(02-19-2021, 01:41 PM)TRS-80 Wrote: Assuming these 32GB cards are new, have you tested them?  Counterfeits are so rampant, we had to put some information in our Wiki about it.[0]
Thanks for the link, I will test them. They are originally packaged and ordered from amazon. So I would hope they are originals.
Amazon has a lot of hinky sellers, it's almost like buying from eBay at this point. Even if the product was sold directly by Amazon it is not unusual for major retailers to be hit with a shipment of counterfeit items. The problem is rampant.
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 23,803 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,416 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 1,997 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,209 10-20-2021, 09:40 AM
  camera firmware problems kqlnut 25 21,534 09-02-2021, 07:49 PM
  Fragile SIM card connector hakkou 1 1,803 08-25-2021, 07:44 AM
Last Post: wibble
  camera + megaixel and strange behavior streak 0 1,678 06-02-2021, 06:45 AM
Last Post: streak
  Sd card slot death? Hurrikan 7 6,516 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 3,973 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Fastest SD card happybot-4678 9 8,533 02-20-2021, 01:08 AM
Last Post: dsimic
