Proximity sensor always active - screen turns off randomly?
(09-10-2020, 05:46 PM)ergo owl Wrote: The proximity censor should only be activated during an active phone call right?
As the bug report says, the issue is a bit more complex than that. The sensor should be activated during a phone call, but not if using a headset or speaker phone. So only the call app knows when the sensor should be activated -> phosh needs to implement a signal of some sort which allows the call app to activate the sensor, and the call app needs to be made to send such a signal.
For those of us not using the phone for phonecalls, the sensor can apparently be set to be always disabled: https://forum.pine64.org/showthread.php?...6#pid77266 (I haven't had time to try it myself.)
Edit: Seems to work. Note that this most likely also disabled the ambient light sensor.
RE: Proximity sensor always active - screen turns off randomly? - by bitnick - 09-11-2020, 09:46 AM
  Screen auto-rotation sensitivity mdk 0 312 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 692 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,490 06-22-2023, 11:20 AM
Last Post: Melechtna
  Lock screen question: always squeekboard tuxcall 1 1,266 02-02-2023, 08:51 PM
Last Post: Haibara23
  [solved] Black screen at boot time mdk 0 1,042 01-13-2023, 03:33 AM
Last Post: mdk
  how to split screen? andrew907 2 1,601 08-08-2022, 09:38 AM
Last Post: andrew907
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 5 2,940 08-02-2022, 03:16 PM
Last Post: treebeard
  on screen keyboard woes vusra 1 1,288 07-18-2022, 03:29 AM
Last Post: vusra
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 886 07-17-2022, 10:34 AM
Last Post: 3x5co
  Won't boot, black screen mdk 4 2,828 07-03-2022, 06:38 PM
Last Post: Chief
