32 bit apps supported?
(08-20-2020, 08:29 AM)fins Wrote: The xojo forums has a thread tracking the issue; Looks like it will come soon, there's also a post in the thread that mentions a wrapper workaround that might work for you.
https://forum.xojo.com/t/arm64-its-time/52793
Thanks for the tips. I saw that too.
Problem is the adding the armhf architecture only causes apt-get to error when trying to find libraries.
32 bit apps supported? - by pcdoodle - 08-15-2020, 06:42 AM
RE: 32 bit apps supported? - by Baggypants - 08-19-2020, 10:36 AM
RE: 32 bit apps supported? - by pcdoodle - 08-19-2020, 04:28 PM
RE: 32 bit apps supported? - by wibble - 08-20-2020, 05:43 AM
RE: 32 bit apps supported? - by tophneal - 08-20-2020, 07:01 AM
RE: 32 bit apps supported? - by fins - 08-20-2020, 08:29 AM
RE: 32 bit apps supported? - by pcdoodle - 08-20-2020, 04:32 PM
  Keyboard not popping up on QT apps 3x5co 1 272 02-08-2024, 11:45 PM
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 869 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 3,211 05-04-2022, 11:45 AM
Last Post: wibble
  Apps and SD Card biketool 2 1,914 03-06-2022, 09:47 AM
  Reskinning Apps for Mobile biketool 6 3,488 12-05-2021, 02:30 PM
  no access to webdav files (for some apps) jsch 0 1,272 11-13-2021, 09:46 AM
Last Post: jsch
  Sizing apps to fit to screen county93 4 3,414 10-23-2021, 11:36 PM
Last Post: bcnaz
  What causes the long delays which switching or starting apps? motox6 10 7,836 10-17-2021, 05:58 AM
Last Post: vortex
  Installed Apps not opening mmd604 5 4,043 10-08-2021, 09:29 AM
Last Post: ragreenburg
  Customized Notifications - Non-native Apps arno_nuehm 2 2,306 10-05-2021, 09:42 AM
Last Post: kqlnut
