wifi comes and goes and prompts for password often
You don't have assign a new SSID to every access point. The phone can handle them as separate access points itself.
Go to settings -> Wifi -> (the settings-icon next to your wifi) -> Details -> Access Point and assign it to only one access point. With six access points you will probably have to write down the BSSIDs you assign.
After that you should see a "new" Wifi with the same SSID in you Wifi settings. Connect to the new Wifi and assign it to a specific access point. It should now be called "Your ESSID 1".
Repeat for all of your access points.
I only have two access points, but it seems to be working quite well. I haven't had any issues with it not handing over to the best available access point.
RE: wifi comes and goes and prompts for password often - by Boern - 08-05-2020, 11:39 PM
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,910 07-18-2023, 08:54 AM
Last Post: junelung
  Wifi doesn't work after update nickolas 2 1,248 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 1,494 01-12-2023, 03:06 PM
Last Post: user641
  Wifi issue since last update and held back updates goku499 11 5,341 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Any fix for bluetooth crash when entering pairing password? kk22 0 860 06-18-2022, 07:51 PM
Last Post: kk22
  Does mobian use a root account and password? rp3 6 7,801 04-04-2022, 07:26 PM
Last Post: parry
  Problem with wifi kubussz 0 882 04-02-2022, 12:57 PM
Last Post: kubussz
  wifi adapter not found.. why? b7l3wui26r 3 2,172 11-29-2021, 10:28 AM
Last Post: beta-user
  Jerky wifi and bluetooth motox6 0 1,263 06-22-2021, 12:50 AM
Last Post: motox6
  SMS notification inconsistent and Wifi issue (waking up?) dcinoz 12 9,378 01-21-2021, 04:20 AM
Last Post: dcinoz
