08-19-2020, 12:40 PM
(08-19-2020, 12:24 PM)plainenough Wrote:Ok, thank you! I guess the text issue is a regression as I have no problems sending and receiving sms or making and receiving calls.(08-19-2020, 12:02 PM)klick Wrote:(08-17-2020, 08:13 PM)bcnaz Wrote:Are you doing a complete reinstall of Mobian? I have been checking daily for updates in the Software app but have not seen any available updates for apps or the OS itself.(08-17-2020, 06:18 PM)plainenough Wrote: Notes: New tester working through this OS. With some new tests. Will be adding a few more tests very soon.Hello,
Results: mobian/2020-08-17
Conclusion: This OS is not ready for the pinephone to be a daily driver. There are some sound quality issues on calls.
Also, Soon I will be creating new threads for testing results to engage a little bit better based on feedback on a few threads I have been monitoring.
I did a "software" update after flashing the above listed 'nightly release' (August 17)
Then the camera does function, - usable but not great yet.
** However, then the sms/text app does not function properly...
The sms/text app will only open after it receives an incoming text.
Yes we are imaging the mobian build daily.
PinePhone UBports CE and Mobian on SD, Mint Mobile, Pinebook Pro Manjaro
