3D Printed Case w/CAD Source Code
(05-23-2016, 08:09 AM)fsa317 Wrote: Do you have STL files for this?
Yes, an STL file (with hole for power button but not GIO pin access) is packed
into the .zip file that you can download.  There is a read-me file in there, as
well as the OpenSCAD source.  Give it a read...
OpenSCAD is pretty easy to use, given the source files.  You can tinker with
the cut-outs without having to wade through all the code.  Also, for example,
you might want to print the two parts of the case as separate jobs.  Whatever.
3D Printed Case w/CAD Source Code - by brf - 05-16-2016, 02:15 PM
RE: 3D Printed Case w/CAD Source Code - by fsa317 - 05-23-2016, 08:09 AM
RE: 3D Printed Case w/CAD Source Code - by brf - 05-23-2016, 12:24 PM
RE: 3D Printed Case w/CAD Source Code - by brf - 06-11-2016, 02:41 PM
RE: 3D Printed Case w/CAD Source Code - by Dup - 07-21-2016, 10:59 AM
RE: 3D Printed Case w/CAD Source Code - by brf - 07-21-2016, 01:51 PM
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 65,073 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 4,014 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,482 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,673 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,221 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 10,159 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 90,242 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 13,237 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 5,366 10-04-2016, 02:45 AM
Last Post: modmypi
Photo Weatherproof case build ltorsini 10 29,645 10-02-2016, 10:49 PM
Last Post: ltorsini
