Netflix, Amazon Prime Video, and Chromium.
(01-05-2021, 11:25 PM)vb_linux Wrote:
(11-13-2020, 08:18 AM)spikerguy Wrote: If you're using Manjaro ARM Linux then I can help you as I am the maintainer of `chromium-docker` package.
Does the Chromium ever updates in Chromium docker? How to update it to latest version?
It does but It cannot be as updated as the regular Chromium.
Technical Reason: We need to find compatible lib-widevine to work with the Chromium version which is dependant on the CHROME-OS Image if they  upgrade lib-widevine then we can upgrade the chromium.
I try to update it but it takes quite some time to find the right matching Chromium version for the widevine we fetch from CHROME-OS recovery Image.
Good question but that is the reason it is recommeded to use chromium-dockers for only DRM content and not for normal browsing.
Manjaro ARM Team.
RE: Netflix, Amazon Prime Video, and Chromium. - by spikerguy - 03-12-2021, 10:46 AM
  Video Flashing/adjusting on boot and reboot jbradley419 0 307 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,695 12-17-2023, 09:29 PM
Last Post: insideau786
  U-Boot, video console, and visual artifacts dsimic 21 19,022 03-16-2023, 07:30 AM
Last Post: Tazdevl
  Kdenlive or other video editing software?? SuttonWillow 4 4,642 05-26-2022, 09:11 PM
Last Post: IsraelRobinson
Question USB-C Video Out Issue dev 2 1,889 02-08-2022, 07:28 PM
Last Post: dev
  Content Streaming on the Pinebook Pro! (Netflix, Spotify, Crunchyroll, YouTube!) ImmyChan 1 2,369 10-07-2021, 11:42 PM
  Video : Review of the PineBook Pro with Armbian NicoD-SBC 1 2,700 07-06-2021, 10:10 PM
  I have two different versions of Chromium on my Pro! Nobot 2 2,675 06-01-2021, 02:34 PM
Last Post: Nobot
  Chromium Dino game is slow/glitchy stozi 0 1,356 04-21-2021, 08:18 AM
Last Post: stozi
  Kdenlive or other video editing software? ImmyChan 2 2,927 01-19-2021, 01:12 AM
