Screen won't shut off when fully closed
found this in a different thread...
\When the "lid close" event is set to just blank the screen it works fine for me (it stays off) but when I set the lid close event to "Sleep" the pbp seems to already be "Woke" when I flip it open. Not sure if my refrigirator light actually goes off either though.
I've noticed there is a magnet in the screen bezel (bottom right) Using another magnet I can toggle the switch (right of backspace key). It could be they are not perfectly alligned and the bezel magnet overshoots the target a bit but because it's a disk shaped magnet the field extending from the edges may be the opposite polarity.
RE: Screen won't shut off when fully closed - by pciman - 07-12-2020, 10:46 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 320 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 3,065 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,068 04-01-2023, 07:55 AM
Last Post: hacknix
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,988 10-08-2022, 06:22 PM
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,027 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,126 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,775 05-09-2022, 05:53 AM
Last Post: gerstavros
  Putting my screen on TV S265 6 4,786 10-07-2021, 08:00 PM
Last Post: ajawadmahmoud
  Screen refresh delay with kernel errors shawnanastasio 31 39,059 04-27-2021, 02:57 AM
Last Post: james64
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 19,817 01-27-2021, 10:48 PM
Last Post: rimaille
