Screen refresh delay with kernel errors
#27
(08-18-2020, 04:46 PM)Lyrixcaz Wrote: I'm on Manjaro arm with the latest kernel at the moment " 5.8.1-1-MANJARO-ARM " i have the package linux-aarch64 installed and when i dmesg i see the messages of:
[  526.782279] rockchip-dp ff970000.edp: Failed to apply PSR -110
[  526.782318] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
If you're running linux-aarch64 then you simply need to add `analogix_dp.enable_psr=0` to your kernel arguments as described earlier in the thread.
RE: Screen refresh delay with kernel errors - by shawnanastasio - 08-21-2020, 01:00 PM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 309 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Black screen by start up bluedemon382 10 3,019 07-27-2023, 07:49 AM
Last Post: dstallmo
  PBP blank screen after updating Manjaro Franko 6 2,030 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro pinebookpro images with kernel 5.7.19 rfm83 11 4,807 01-22-2023, 10:05 PM
Last Post: rfm83
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 2,898 01-22-2023, 09:55 PM
Last Post: rfm83
  minimal kernel .config? alchemist 5 5,954 08-15-2022, 06:28 PM
Last Post: svmhdvn
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,011 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,110 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Looking for Screen LCD Panel for the Pinebook Pro gerstavros 3 2,762 05-09-2022, 05:53 AM
Last Post: gerstavros
  PinebookPro Build Errors mexsudo 3 2,943 01-30-2022, 08:36 AM
Last Post: mexsudo
