Soldering internal Wifi/Bluetooth antenna
(06-18-2020, 08:44 AM)petet0n76 Wrote: Hello,
just did a complete disassemble of my Pinebook Pro. When I tried to disconnect the internal wireless antenna from the CPU Board the socket came off from the board, damage caused. Would like to repair without replacing the CPU Board, are there two potential solder joints (shield/signal) where the antenna can be soldered to ? If it cannot be fixed...USB Wireless dongle seems to be the remaining option.
Any hint appreciared, Peter
Sorry to knows about antenna socket comes off. You can directly solder to the PCB soldering point but needs good study hand and soldering skill.
RE: Soldering internal Wifi/Bluetooth antenna - by tllim - 06-20-2020, 12:01 PM
  Kernel Not Detecting Wifi tallfrye 10 1,061 01-01-2024, 06:57 AM
  Connection to WiFi with OWE IhorOlkhovskyi 1 1,412 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  Is there a way to turn off Wifi completely? jirow 10 7,992 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 1,324 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,422 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 1,405 09-16-2021, 02:50 AM
Last Post: hellojack
  Advice on increasing WIFI range stozi 2 4,103 03-29-2021, 06:57 AM
Last Post: barray
Lightbulb Bluetooth headsets - what works? embhorn 17 24,108 03-22-2021, 11:45 PM
Last Post: ab1jx
  Curious about problem with PBP Wifi kendew 3 4,771 01-14-2021, 11:16 AM
Last Post: clover
  Bluetooth microphone not detected mjc 2 3,915 10-31-2020, 01:34 PM
Last Post: wrzomar
