reset sound after suspend to memory (deep sleep)
(08-29-2021, 12:46 PM)JGkn Wrote:   Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.33 running: yes
K, that's probably where the problem lies - my script is geared towards PulseAudio and does not have any provisions for PipeWire. The core idea of the script is to first make the permissions on the audio device such that no new process can open it, then stop all the existing processes (which on a system using PulseAudio should be only the PulseAudio user session instance), then do the bind/unbind, and then restart the audio server. I haven't yet played with PipeWire--PulseAudio works well enough for my needs that I don't feel like fiddling with a less mature option, even if theoretically superior--so I cannot give you ready-to-go solution. You'll have to figure out yourself how to make sure PipeWire doesn't use the sound card while the driver is being rebound. But my guess is you might be able to simply replace the pulseaudio.s(ervice|ocket) with the equivalent PipeWire systemd units, assuming they still run in user session context and not system-wide context. If they run in system-wide context you should be able to get rid of all the dbus-related shenanigans.
This message was created with 100% recycled electrons
RE: reset sound after suspend to memory (deep sleep) - by moonwalkers - 08-29-2021, 10:32 PM
  Sleep and external display - Are there any options? chris88233 7 1,804 09-04-2023, 09:03 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,467 08-31-2023, 04:20 PM
Last Post: TRS-80
  Rkvdec memory leak? Abhinav 2 871 06-02-2023, 08:55 AM
Last Post: Abhinav
  Sound on Armbian Bram 1 934 04-01-2023, 03:16 PM
Last Post: TRS-80
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 1,206 03-24-2023, 04:25 PM
Last Post: srs5694
  With the help of a friend, I installed a beautiful deep os distribution, but I won't wangyukunshan 0 623 03-03-2023, 10:56 PM
Last Post: wangyukunshan
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 3,062 11-02-2022, 02:33 PM
Last Post: kebab
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 2,014 10-31-2022, 10:14 AM
  Loud distorted speaker sound when connecting to power supply myself600 2 1,233 09-21-2022, 12:11 PM
Last Post: myself600
  How to make manjaro sleep or hibernate? KDE? regretfulpineuser 0 998 06-20-2022, 12:56 AM
Last Post: regretfulpineuser
