Rkvdec memory leak?
Anyone else seeing high memory usage with rkvdec/rockchip_vdec? I am seeing high memory usage with both GStreamer and FFmpeg (https://github.com/jernejsk/FFmpeg) clients so, if other people are also having issues, it seems like it might be an issue in the kernel driver. Performance is quite good until it starts swapping however. I see 3.5 GiB of shared memory usage before it hangs/starts swapping. I'm using kernel 6.1. It's also possible that it is somewhere else like Panfrost or Mesa and I guess I would need to use Kmemleak to confirm but I'd like to know if this is a known issue before I test further.
It seems that issue occurs with the Moonlight (FFmpeg) and Epiphany (Gstreamer) client but not MPV (FFmpeg) which suggests that it might be a user space issue (thanks PaulFertser).
After further testing, this issue does not seem to occur when using Moonlight with QT's EGLFS on a TTY or when using Moonlight on X11. It only occurs when using Moonlight on Wayland.
  reset sound after suspend to memory (deep sleep) Der Geist der Maschine 16 17,010 10-18-2021, 07:31 PM
Last Post: Syonyk
  Better rkvdec support in 5.11? ShootTheMoon2 2 3,680 02-28-2021, 07:10 PM
Last Post: ShootTheMoon2
