Battery draining with external power while under load?
(06-23-2020, 05:09 PM)Der Geist der Maschine Wrote: Hello Syonyk, this is true for the Pine Time. I don't follow the Pine Phone, maybe that's also true for the Pine Phone. As far as I know, the Pinebook Pro is not advertised as developer hardware. Only Ayufan, MrFixIT, Luke and maybe others got developer hardware way over a year ago.
At a maximum, it's still community development hardware. It's possible to use one as a daily driver, but I wouldn't recommend that for someone who was not already a reasonably skilled Linux admin with some hardware experience. There are still plenty of rough edges, like the latest wifi firmware screwing up the wireless connectivity, the blend of things required for deep sleep, and sound not working reliably after that.
I put things like the charging behavior in the "It's still beta" category. The right answer, IMO, would be USB-C power delivery hardware, but that's not what the unit has.
If I load the system up hard, I can get 3.5A out of the battery at around 3.8V - that's 13.5W. It should hold that on the barrel plug, but it's observably not - or it heats up and can't keep up. Not sure which.
There's nothing wrong with that - it's just a design decision they made. But I wouldn't give a PBP to a non-technical friend yet for anything resembling regular use.
RE: Battery draining with external power while under load? - by Syonyk - 06-23-2020, 06:11 PM
  Lockable-until-power-cycle persistent storage Melab 0 760 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 874 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 657 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,315 02-25-2023, 09:00 PM
Last Post: badguru
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,256 12-01-2022, 02:50 AM
  Battery Frost1776 1 1,099 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,692 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,390 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,647 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 5,196 02-10-2022, 11:52 AM
