Cant get anything to work
(05-12-2016, 09:10 AM)tkaiser Wrote:
(05-12-2016, 08:56 AM)Luke Wrote: A good walkthrough by tkaiser.
But I assume that you want Android
Even if he wants Android he should follow the steps outlined above. Since with Android he has NO WAY to check whether his board is DOA or not if he runs into the "no display" problem you should be well aware of!
Using the small Linux image and following exactly every step above he will be able to rule out all known issues that prevent burning an OS image successfully. And by using Linux and connected Ethernet the leds on the Ethernet jack can be used as "not DOA" indicator. That's the only known way to really verify if your board is dead or not (if you forget about the crappy Micro USB connector that can also be the reason why Pine64 never successfully boots --> undervoltage/undercurrent as described in the link above)
Choosing Android for DOA detection is impossible since Andoid will refuse the 1st boot with connected Ethernet. So please stop posting recommendations that are already known to NOT work (same here. Why do you tell people an issue that might be related to underpower can be fixed by a kernel update?!)
tkaiser,
Quoting the OP "I am very new to all this so i really need basic tutorial, but even the basic videos i have watched still all direct me to the pine wiki page for download, and none of them work... super frustrated. please help." - based on this I feel it is safe to assume that this isn't a case of a DOA board but rather a case of a lack of know-how to install an OS.
In respect to the other post, I have responded to you there.
Thank you for our input.
Cant get anything to work - by agentwright - 05-12-2016, 08:10 AM
RE: Cant get anything to work - by Luke - 05-12-2016, 08:13 AM
RE: Cant get anything to work - by tkaiser - 05-12-2016, 08:19 AM
RE: Cant get anything to work - by benpope81 - 05-12-2016, 08:40 AM
RE: Cant get anything to work - by Luke - 05-12-2016, 08:56 AM
RE: Cant get anything to work - by tkaiser - 05-12-2016, 09:10 AM
RE: Cant get anything to work - by Luke - 05-12-2016, 11:30 AM
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 4,459 11-16-2017, 02:14 PM
Last Post: Skivholme
  Does snapchat work on pine64 with android? user875545 1 4,220 08-29-2017, 12:05 AM
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 7,003 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,021 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 5,969 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,630 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,620 09-11-2016, 06:29 AM
Last Post: ameth
  (potential) work-around for Playstore authentication issue Luke 31 43,658 09-01-2016, 05:07 PM
Last Post: MarkHaysHarris777
  Does wireless mouse work? marco97pa 5 6,154 06-30-2016, 08:40 PM
Last Post: pedalman
  How the power button is supposed to work? rakib-hasan 8 8,556 04-27-2016, 01:53 AM
Last Post: Tarjei85
