Cant get anything to work
A good walkthrough by tkaiser.
But I assume that you want Android on you Pine64 - seeing as you posted in the Android section - and that you are a relatively inexperienced user.
So I suggest this simple way of getting Android running:
1) download Phoenix https://drive.google.com/file/d/0B0cEs0l...U1NFk/view
2) download Android img for Phoenix http://files.pine64.org/os/android/andro...ixCard.zip
3) Open Phoenix and point to the correct drive
4) chose the image you've downlaod and make sure Phoenix is set to burn in 'Startup!
5) Burn
Why I suggest this is because Phoenix shows error messages if the burn fails.
You can read all about burning DD images on the forums if you decide to go that route.
Hope this helps
Cant get anything to work - by agentwright - 05-12-2016, 08:10 AM
RE: Cant get anything to work - by Luke - 05-12-2016, 08:13 AM
RE: Cant get anything to work - by tkaiser - 05-12-2016, 08:19 AM
RE: Cant get anything to work - by benpope81 - 05-12-2016, 08:40 AM
RE: Cant get anything to work - by Luke - 05-12-2016, 08:56 AM
RE: Cant get anything to work - by tkaiser - 05-12-2016, 09:10 AM
RE: Cant get anything to work - by Luke - 05-12-2016, 11:30 AM
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 4,492 11-16-2017, 02:14 PM
Last Post: Skivholme
  Does snapchat work on pine64 with android? user875545 1 4,252 08-29-2017, 12:05 AM
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 7,048 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,228 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 6,010 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,661 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,634 09-11-2016, 06:29 AM
Last Post: ameth
  (potential) work-around for Playstore authentication issue Luke 31 44,232 09-01-2016, 05:07 PM
Last Post: MarkHaysHarris777
  Does wireless mouse work? marco97pa 5 6,227 06-30-2016, 08:40 PM
Last Post: pedalman
  How the power button is supposed to work? rakib-hasan 8 8,679 04-27-2016, 01:53 AM
Last Post: Tarjei85
