05-20-2020, 08:42 AM
Is there a pinout for the RockPro 64 MIPI-CSI connector? Is this connector standardized across boards such as the Pi 3/4 and the Jetson Nano?
RockPro 64 MIPI Pinout
05-20-2020, 05:16 PM
(05-20-2020, 08:42 AM)carbotaniuman Wrote: Is there a pinout for the RockPro 64 MIPI-CSI connector? Is this connector standardized across boards such as the Pi 3/4 and the Jetson Nano? All the schematics are linked from the wiki, which also identifies all the RockPro64 connectors. No idea any pin compatibility - the physical connector is standard.
05-20-2020, 08:39 PM
I see the schematic. Do you happen to know what voltage the SCL and SDA lines (on the MIPI CSI port) operate at?
05-21-2020, 03:41 AM
(05-20-2020, 08:39 PM)carbotaniuman Wrote: I see the schematic. Do you happen to know what voltage the SCL and SDA lines (on the MIPI CSI port) operate at? Nope sorry. And due to lockdown my RockPro and multimeter are in different locations.
Can i use this Emmc for Rockpro 64 | Supratec | 2 | 669 |
12-20-2023, 09:12 AM Last Post: wdt |
red led blink on rockpro pine 64 | Daniele14521 | 0 | 1,127 |
09-26-2022, 01:40 AM Last Post: Daniele14521 |
Is my rockpro dead? | k0sm | 6 | 4,806 |
12-30-2021, 07:32 PM Last Post: Rocklobster |
Rockpro 64 with analog input | jintao6889423 | 3 | 5,247 |
05-13-2021, 09:41 PM Last Post: KC9UDX |
Camera sensor support on MIPI lines | abhimanyu_gr | 0 | 1,717 |
01-22-2021, 09:23 AM Last Post: abhimanyu_gr |
Fedora 32 on ROCKPro 64. | joeblues91 | 4 | 7,274 |
07-26-2020, 12:12 PM Last Post: revoman |
RockPro 64 V2.1 Boot problem only DDR Version ... message | nutilius | 5 | 7,165 |
05-02-2020, 03:26 AM Last Post: freeviv |
Calculate clock frequency for MIPI DPHY using different ref_clock value | skumar | 1 | 3,063 |
06-07-2019, 03:01 PM Last Post: Nikolay_Po |
Non burst mode in MIPI DSI | skumar | 0 | 1,978 |
06-06-2019, 12:54 AM Last Post: skumar |
Rockpro 64 | maurora | 1 | 2,827 |
05-24-2019, 09:50 AM Last Post: Luke |
