#51
Good job. The interface is more responsive than pmOS. I surely prefer it to pmOs
#52
I tested the new build leaving the phone idle overnight with WiFi and modem on. It lasted all night. The only thing is not working are the calls
#53
.jpg   photo_2020-02-28_11-21-39.jpg (Size: 118.96 KB / Downloads: 381)
.jpg   photo_2020-02-28_11-21-35.jpg (Size: 70.76 KB / Downloads: 378)
.jpg   Xfce1.jpg (Size: 66.57 KB / Downloads: 327)
Just installed XFCe.  I like it more and now it's look more like Linux Phone Smile
The only issue --- no keyboard at the moment Sad
#54
(02-28-2020, 04:23 AM)harvey186 Wrote: Just installed XFCe.  I like it more and now it's look more like Linux Phone Smile
Cool! Here come the follow up questions =)
Which packages did you install?
How did you boot in to xfce?
"- is there already a tool for overclocking it desperately?"
#55
(02-28-2020, 05:27 AM)murak Wrote: Which packages did you install?    -->  I have used 'sudo apt install task-xfce-desktop'
How did you boot in to xfce?  -->  I'm using these commands: '
systemctl stop phosh
sudo pkill -KILL -u debian
 Than you get the login screen and before add the PW change to desktop via wheel left of OK Button
But be carefull. The device getting hot, very hot and don't use 'Weston'. you can't change back.
#56
For anyone following along that hasn't seen it yet watch this Librem video and it works really well . Keyboard is working now, sync works perfectly, browsing is fluid. One step closer to DebPhosh daily driving!
https://www.youtube.com/watch?v=6YoNuJN3Z-A
#57
Cool Smile
But just so you know, starting from the next release, there will be no display manager, you'll have to install gdm3 as well (or lightdm, should work too)
(02-28-2020, 09:34 AM)nas Wrote: It appears a voltage patch needs to be applied to prevent the lcd being fried. Hopefully, the next image version will have this baked in?
Yep, I've just uploaded a new kernel including this fix, you're an "apt upgrade" away from it Wink
#58
parkerwbFor anyone following along that hasn't seen it yet watch this Librem video and it works really well . Keyboard is working now, sync works perfectly, browsing is fluid. One step closer to DebPhosh daily driving!
But that's not a PinePhone in the video, or ??
#59
is there a difference between 'sudo apt update' and using a the latest (new) image ? Because with new image a lost all my working apps.
#60
There are a couple differences, but nothing really huge... You'll probably have to manually uninstall gdm3, but that's pretty much all
I should do a bunch of metapackages to make things better when I have some spare time.
  atinout binaries for mobian/debian? NeutralGrey 2 110 05-13-2024, 02:42 PM
Last Post: Gumur
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 26 2,806 05-09-2024, 03:08 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,761 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,565 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,751 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 3,132 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,378 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 169,596 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,394 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,292 03-01-2023, 04:45 PM
