Pine64 Board Appeared Dead (SOLVED)
Hi All,
  I received my Pine64 2 Gig board as promised.  When I got it, I immediately took to getting it up and running, however, I was quickly stumped.
First, the light was red, which usually indicates an error, I read up and found that it is just the color of the power light.
Second, I loaded Android on an SD card following the instructions, but when I plugged the board in nothing would appear on the screen. The red light was lit up, but it seemed like the thing was dead. Nothing showed on the screen. I tried Remix, but no difference. I began to suspect that I had a bad board. Tonight, the thought occurred to me, that maybe it wasn't the board. I plugged the board into my TV and found it was working just fine.  The problem was my HDMI to DVI computer monitor setup.  I believe the resolution of the board exceeded what my monitor could handle, and therefore just didn't display anything at all. I still have no idea how to dial back the resolution so my monitor will work, but that is a solvable problem. At least I know the board is good.
If you suspect your board is dead, try hooking it up to an HDMI TV input.
Hope this helps others,
Wauna
Question External storage problem for pine64 Dani6102 4 1,754 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,311 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,166 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,914 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,141 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,789 09-14-2020, 09:55 AM
Last Post: PaddyChan
  How to build Webradio from Board A64 ? Bebert 5 7,393 08-19-2020, 12:49 PM
Last Post: Bebert
  Pine64 OS dpcons 2 4,982 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,850 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,621 11-25-2019, 12:19 PM
Last Post: Partymack711
