ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64
I noticed that the pine store has the following,
PINE64 USB SERIAL CONSOLE/PROGRAMMER - https://www.pine64.org/?product=pine64-u...programmer
Will this function as designed via the serial adapter on the Stereo Audio DAC Add-on Board?
Also, if the Serial Console/Programmer peripheral does work with the Stereo Audio DAC Add-on Board, may I use it (if even in a limited way) as an additional USB adapter? (I suspect not, but I wanted to be sure, and confirm or clarify my (mis)understandings.)
(11-28-2018, 03:06 AM)jovval Wrote: I noticed that the pine store has the following,
PINE64 USB SERIAL CONSOLE/PROGRAMMER design for PINE A64 board that has EXP port.
For ROCK64, please use the PADI serial console, https://www.pine64.org/?product=padi-serial-console
However, the Audi DAC board header occupied the UART pins and you will been to solder three pins (Rx, Tx, and Gnd) to access into console.
I have the PADI serial console and I find it works nicely. (I should have mentioned as much.)
(1) The pins on the AUDIO DAC ADD-ON BOARD's UART connection are not soldered?
That is, are they just for appearances? The pins presently connect to nothing?
Seems strange, but upon scrutinizing the board, I can see no leads to its UART receptacle.
(2) Were I properly to solder a 5V connection (in addition to the others) to the UART connection, is there any way (that you see, with code) to convert this UART to a USB 1.x-compatible output?
I am really only considering USB 1.x speeds. At the very least, I wonder if I could arrange having a keyboard attached thusly.
Yeah, this would be a significant effort, and I would more logically just use a USB 2.0 hub on one of the extant ports (but connection via a hub may not be possible for some fussy hardware). I am just curious about its feasibility.
  Are HW design files available for ROCK64? irenek 3 4,771 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 331 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,065 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 623 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,227 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,746 11-07-2022, 05:45 PM
Last Post: olivercfc
  Audio Pot Board Questions vfr400racer 4 3,110 10-11-2022, 09:21 PM
Last Post: Roberto2020
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,522 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 2,623 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,521 03-04-2022, 06:56 AM
Last Post: killor
