09-10-2018, 05:28 AM
DietPi for the RockPro64
09-10-2018, 12:48 PM
I'll try this out this evening.
09-11-2018, 01:37 AM
(This post was last modified: 09-11-2018, 01:46 AM by romtorwator.)
Interestingly, due to which the Odroid-N1 has higher performance in the rating DietPi?
my SOHO NAS RockPro64 4GB v2.1 / eMMC 32GB / PCIe -> 4*SATA Marvell 88SE9235 / SD-card 64 GB / NAS Casing / image Debian Stretch Minimal / Kernel 4.4.xxx ayufan my Multimedia desktops: ASUS H310T G5500, ODROIDs -XU4, -XU3, -C2, -C1; my trash BananaPi; RPi B, B+; ODROID-W
09-11-2018, 04:41 AM
(09-11-2018, 01:37 AM)romtorwator Wrote: Interestingly, due to which the Odroid-N1 has higher performance in the rating DietPi? First of all, the Odroid-N1 is no more. Secondly, regarding file performance, probably because their eMMC modules are faster (than original/ older) than PINE64 eMMC modules. As for the CPU, DietPi uses ayufan's kernel and for the time being ayufan chose "stability over performance" - so the rk3399 is clocked a little slower (1.8ghz).
09-11-2018, 06:32 AM
I had a look at this last night. Even though it says GPU features (e.g. Kodi, Desktop) don't work, you can get to the desktop if you tweak the xserver config a bit. It looks like it still needs work though. Youtube and similar websites weren't working. I tried experimenting with manually installing some of ayufan's libmali stuff but that didn't help.
10-22-2018, 02:22 PM
I installed DietPI.
I couldn't setup xserver (screen not found). Could you tell us what you did in order to bring up the xserver? Besides that, it's amazing. It has an EXCELLENT setup menu, and it's really fast! I think it's faster than the bionic lxde.
10-22-2018, 07:16 PM
(10-22-2018, 02:22 PM)jannerman Wrote: I installed DietPI. I think I commented out something in the /etc/X11/xorg.conf file, don't remember if it was a line that said "armsoc" or not, but it might be. Try commenting out the driver line in that file and see if that helps.
You where right.
It was in /etc/X11/xorg.conf.d I renamed the armsoc config. No sound and GPU accelaration. Same issues with PCIe card (system freezes in X11) Still, is great as a server
11-19-2018, 09:36 AM
Added DietPi (v6.14) on Pine64 Installer
11-19-2018, 12:39 PM
(This post was last modified: 12-10-2018, 06:13 AM by spatial_dreams.)
(10-22-2018, 07:16 PM)Pitcrawler Wrote:(10-22-2018, 02:22 PM)jannerman Wrote: I installed DietPI. Thanks for posting this, I was able to get xorg to run by doing this, but does this prevent X from utilizing the MALI T-860? |
