Thanks to @jmcneill for creating the builds!!!
First boot
Update to latest current
As root user:
After reboot
Update the /etc/ configuration
Verify everything works, then clean up and reboot
Based on @jmcneill instructions:
Source https://gist.github.com/e-minguez/0f637c...ddbc5575f5
- Download latest from http://www.invisible.ca/arm/
- dd'it to a microsd. In linux:
sudo dd if=./NetBSD-evbarm-aarch64-201811042130Z-pine64.img of=/dev/sdb
First boot
- Plug the microsd into the pine
- Boot the pine and wait for a couple of reboots (disk expansion)
- Login as root (no password)
- Configure password for root user
passwd
- Create user (in my case, 'edu') and add it to the wheel group
useradd -m -G wheel edu
passwd edu
- Edit /etc/wpa_supplicant.conf with the appropriate ssid/psk:
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=wheel
network={
ssid="my favourite network"
key_mgmt=WPA-PSK
psk="hunter2"
- Editing /etc/rc.conf to enable wpa_supplicant at boot. Notice my usb wireless adapter is urtwn0 (ifconfig will show you all the adapters):
wpa_supplicant=YES
wpa_supplicant_flags="-i urtwn0 -c /etc/wpa_supplicant.conf"
- Start wpa_supplicant service:
chmod 600 /etc/wpa_supplicant.conf
/etc/rc.d/wpa_supplicant start
- Verify it:
ifconfig urtwn0
As root user:
# Create a temporary directory
mkdir -p /root/tmp/kernel
cd /root/tmp/kernel
# Backup the current NetBSD kernel
cp /netbsd /onetbsd
# Download a full tar with kernel and dtb files
ftp https://nyftp.netbsd.org/pub/NetBSD-daily/HEAD/latest/evbarm-aarch64/binary/sets/kern-GENERIC64.tgz
tar xzvf /root/tmp/kernel/kern-GENERIC64.tgz
# Overwrite the current NetBSD kernel and dtb files
cp ./netbsd /netbsd
cp sun50i-a64-pine64* /boot/dtb/allwinner/
# Reboot
reboot
After reboot
mkdir -p /root/tmp/sets
cd /root/tmp/sets
# Download and untar all sets
for x in base comp games man misc modules tests text xbase xcomp xfont xserver; do ftp https://nyftp.netbsd.org/pub/NetBSD-daily/HEAD/latest/evbarm-aarch64/binary/sets/$x.tgz; done
for x in base comp games man misc modules tests text xbase xcomp xfont xserver; do tar -C / -zxvpf $x.tgz; done
for x in etc xetc; do ftp https://nyftp.netbsd.org/pub/NetBSD-daily/HEAD/latest/evbarm-aarch64/binary/sets/$x.tgz; done
etcupdate -s etc.tgz -s xetc.tgz
rm -Rf /root/tmp
reboot
<jmcneill> Updated sets are on the autobuild server: http://nycdn.netbsd.org/pub/NetBSD-daily/HEAD/latest/evbarm-aarch64/binary/sets/
<jmcneill> Backup current (working) kernel: cp /netbsd /onetbsd
<jmcneill> Then take "./netbsd" from kern-GENERIC64.tgz and put it as /netbsd
<jmcneill> and you probably want to update the dtb in /boot/dtb/allwinner/ to match
<jmcneill> (latest dtb is in that same file)
<jmcneill> reboot with the new kernel, make sure it works..
<jmcneill> (you need to be running the new kernel for this latest step -- old kernel may not support new userland)
<jmcneill> then extract sets..
<jmcneill> for x in base comp games man misc modules tests text xbase xcomp xfont xserver; do tar -C / -zxvpf $x.tgz; done
<jmcneill> note that I skipped the debug sets (they are big) and etc/xetc sets (we upgrade those separately)
<jmcneill> To see what sets you have installed, ls /etc/mtree/set.*
<jmcneill> Then to update etc and xetc: etcupdate -s etc.tgz -s xetc.tgz
